How Do You Calculate Initial Velocity in an Elastic Collision Problem?
The problem involves calculating the initial velocity of a ball in a perfectly elastic collision scenario. The setup includes a 44.0 g ball fired horizontally toward a 110 g ball hanging from a string, with the latter swinging to a maximum angle after the collision.
  • Mixed
  • Participants discuss the conservation of momentum and energy equations relevant to elastic collisions.
  • Some participants attempt to relate kinetic energy and potential energy to find the initial velocity.
  • Questions arise about how to combine the equations and the correct interpretation of height in the context of the problem.
  • There is uncertainty regarding the state of the 44 g ball after the collision and its impact on the energy conservation equation.
The discussion is ongoing, with participants exploring different interpretations of the equations and the physical setup. Some guidance has been offered regarding the relationships between kinetic and potential energy, but no consensus has been reached on the correct approach or assumptions.
Participants note potential confusion regarding the height calculation and the implications of the 44 g ball's motion post-collision, indicating a need for clarification on these points.
David Lee
I need help!
A 44.0 g ball is fired horizontally with initial speed vi toward a 110 g ball that is hanging motionless from a 1.10 m-long string. The balls undergo a head-on, perfectly elastic collision, after which the 110 ball swings out to a maximum angle = 52.0.
What was vi ?
Conservation of momentum:
m1vi1 + m2vi2 = m1vf1 + m2vf2
Conservation of energy:
1/2m1(vi1^2) = m2gy
I tried to solve these problem with those 2 equations, but it still doesn't work. I compeletly massed up with these concepts. Can anyone help me with this problem with exact answer?
Thank you
You almost have the energy conservation right.
ke of first ball -> ke of second ball -> potential energy of second ball.
you know m1, m2, and h so just find v1
I do not know how to combine those two equations. Can you through specific steps by using numbers?
ke of first ball = 1/2 m1 v^2
pe of 2n ball = m2 g h
Just set them equal
1/2 * m1 * v1^2 = m2 * g * h
1/2 * 0.044 * v1^2 = 0.110 * 9.8 * h
You need to do a bit of trig to get h, then it's simple
Just set them equal
okay, thank your so far. I got the h as 0.110cos53, but is it right? or h is (0.110 - 0.110cos53 )?
which one is right?
Just set them equal
There is no wording in the problem that says that the 44 g is at rest after the collision. It seems to me that the energy conservation equation is missing the kinetic energy of the 44 g ball after the collision. One needs to solve the momentum conservation equation for the velocity of the 44 g mass after the collision and substitute in the modified energy conservation equation.
  • · Replies 16 ·
18K
