What is the net magnetic field at a point due to perpendicular currents?
The discussion revolves around calculating the net magnetic field at a specific point due to two perpendicular currents in wires. The subject area involves electromagnetism, specifically the behavior of magnetic fields generated by current-carrying conductors.
  • Exploratory, Assumption checking
  • Participants discuss the method of determining the net magnetic field by considering the contributions from each wire separately and question the correct approach to adding these fields, particularly regarding their directions.
Participants are exploring the relationship between the currents and the resulting magnetic fields, with some guidance offered on considering the direction of each field. There is an ongoing examination of how to properly combine the magnetic fields from the two wires.
There is a focus on the signs of the magnetic fields and how they relate to the directions of the currents, with some uncertainty about the correct approach to adding these fields together.
thebigbluedeamon
I cannot figure how this works..
A wire carries a 7.00 A current along the x-axis and another wire carries a 6.00 A current along the y-axis. What is the magnetic field at point p located at x=4.00m and y=3.00m.
Since each wire carries its own magnetic field, my instinct is saying that I just need to add the magnitude of the two fields. But that doesn't seem correct.
A speedy reply would be greatly appreciated.
That's all there is to it. Be sure you have the correct sign (direction) of each field when you add them.
So would the direction of the field in the y-direction be negative and the direction in the x-direction be positive?
I guess I would end up with something like...
Bnet = Bx - By
Sounds easy enough for me.
The current along the y-axis creates a field (at the point in question) that is in the -z direction; the current along the x-axis creates a field in the +z direction.
  • · Replies 21 ·
