| Thread Closed |
Decay chain (Bi -> Po -> Pb) |
Share Thread |
| Dec1-09, 11:32 AM | #1 |
Hi I'm trying to do a question on nuclear decay chains. The question is:
Bi-210 decays to Po-210 by beta decay (half life = 7.2 days), and this decays by alpha decay to Pb-208 (half life = 200 decays). If A substance is initially pure Bi-210, when does the alpha emmision peak? So far Ive got Bi(0)=1, Po(0)=Pb(0)=o Bi(t) = Bi(0)exp(-Lt) (L being the decay constant, t_1/2 = ln(2)/L) and dPo(t)/dt = L(Bi(0)exp(-Lt)) -L'Po(t) Obviously I just need to find when Po(t) is at a maximum, to find the corresponding maximum in alpha emmision, but I can't solve for Po(t) can anyone help? |
| Dec1-09, 11:06 PM | #2 |
Admin
Well, think on mean Bi-210 => to Po-210 => Pb-206. Half-lives are 7.2 and 200 days respectively, although reliable sources indicate half-life of Po-210 is 140 d (Hyperphysics) or 138.376 d (BNL NNDC).
http://hyperphysics.phy-astr.gsu.edu...radser.html#c3 This is at the bottom end of the U-238 decay series. Also - apparently Bi-210 can decay to Tl-206, which beta decays to Pb-206, but it's almost 100% alpha. To solve the problem, make sure one has the correct half-lives or decay constants. One has to develop two differential equations. One deals with the change (decay) in amount of Bi-210, which is also the production rate of Po-210. The other equation deals with the production and decay of Po-210 (production of Pb-206). The peak alpha emission from Po-210 occurs when the amount of Po-210, or when the rate of change is zero (dP/dt = 0), or when production rate = decay rate. This is called transient equilibrium. |
| Thread Closed |
Similar discussions for: Decay chain (Bi -> Po -> Pb)
| Maximum energy of a decay product in three(or more)-particle decay | Advanced Physics Homework | 0 | ||
| Ball and chain- (kidding, no chain) | General Physics | 2 | ||
| Radioactive chain decay | Calculus & Beyond Homework | 4 | ||
| Radioactive Decay chain and Masses of Products | General Physics | 4 | ||
| radioactive decay equilibrium when decay constants are equal | Biology, Chemistry & Other Homework | 2 | ||
