Solar Cell Physics Coursework (Calculating Internal Resistance)
The discussion revolves around calculating the internal resistance of a solar cell within a circuit setup involving a voltmeter, ammeter, and variable resistor. The original poster expresses concern about the voltage remaining constant while the current changes, leading to a misleading graph that suggests zero internal resistance.
  • Participants discuss the impact of varying the resistance on the voltage and current readings. Questions are raised about the resistance values used and the implications of a constant voltage on the internal resistance calculation.
Some participants have offered insights into the relationship between the internal resistance and the load resistance, suggesting that smaller load values may yield more variable voltage readings. Others note the non-linear characteristics of the solar cell's voltage-current curve, indicating that further experimentation may be necessary.
There is an indication that the original poster may not have varied the load resistance sufficiently to observe changes in voltage, and the nature of the solar cell's behavior under different conditions is under consideration.
elyas22
Basically I want to Calculate the internal resistance of a solar cell.
I set up a circuit with a voltmeter across the solar cell and an ammeter and variable resistor in series with the solar cell. The variable resistor is the load.
Image at http://elyaschaudhary.schools.officelive.com/video.aspx
As i change the resistance the value of current changes which is GOOD
However the Voltage stays the same BAD
This results is a graph with a horizontal Line implying that internal resistance is 0. BAD
I need the current and voltage to change i think to get a graph which will be able to give me the EMF and Internal resistance.
Could some one please explain how this is done
Thank you very much
Elyas
How low in resistance did you go? If you short out the solar cell, you will definitely get a lower voltage.
If you replace the solar cell with a voltage source (V) and an internal resistance (r) in series, then calculate the measured voltage (V1), you will see that a constant V1 just means that the internal resistance r is small compared to R. You will need to do the experiment again with smaller values of R that do cause a change in V1 in order to calculate r.
Also, the v-i curve for a solar cell is not a straight line.
