Confusion about momentum question
  • Thread starter Thread starter dark-ryder341
    Confusion Momentum
The discussion focuses on understanding the application of sine and cosine in vector momentum calculations, specifically in the context of a collision between two hockey players. The example provided involves two players with masses of 90 kg and 100 kg, moving at velocities of 10 m/s and 15 m/s, respectively. The key equations used are the initial momentum equation (pi = m1v1i + m2v2i) and the final momentum equation (pf = (m1+m2)vf). The confusion arises from determining when to apply sine and cosine for vector components, which is clarified by recognizing that the cosine function is used for components along the x-axis and sine for components along the y-axis.
  • Understanding of basic physics concepts, specifically momentum and collisions.
  • Familiarity with vector decomposition in two dimensions.
  • Knowledge of trigonometric functions, particularly sine and cosine.
  • Ability to apply Newton's laws of motion in problem-solving scenarios.
  • Study vector decomposition techniques in physics problems.
  • Learn how to apply trigonometric functions in real-world physics scenarios.
  • Explore momentum conservation principles in two-dimensional collisions.
  • Practice solving collision problems using different angles and velocities.
This discussion is beneficial for physics students, educators, and anyone looking to deepen their understanding of vector momentum calculations and trigonometric applications in physics.
dark-ryder341
Hmm, well, this isn't an actual homework question. It's more of a general one, but it does apply to homework. What I want to know is, for momentum, how do you know when to use sine and cosine for vectors? Likeeee, let me show you an example of what I mean:
This is a depiction of the following: two hockey players approach each other at an angle with different speeds. mass(m1)=90kg, velocity(v1)=10 m/s; (m2)=100kg, (v2)=15 m/s. They collide and stick together. The question asks to find the final velocity of the two.
pi = m1v1i + m2v2i
pf = m1v1f + m2v2f >>> (m1+m2)vf
Now, here's the beginning of how it's solved, according to my teacher.
pi = (90+10)i + 100(15cos(theta)i(hat) + 15sin(theta)j(hat)) = (900+1300)i(hat) + 750j(hat)
I'm going to stop here, as this is what I don't understand. How did he figure out that he should use 15cos(theta) and 15sin(theta) rather than just 15 m/s? And how did he know that i(hat) was using cosine, rather than sine? If you understand what I mean...I'm just not sure where the cos and sin, came from, in other words, and how he knew what order it went in. There is another question in my book where it's switched - i(hat) is sine and j(hat) is cosine.
Thanks for any help!
First of all select x and y axis. In the given problem v1 is along x-axis with i as the unit vector. j is the unit vector along y-axis.
pi = m1v1*i + m2v2*cosθ*i + m2v2*sinθ*J
If A and B are the two vectors with an angle θ between them, then the component of B along A is B*cosθ and component perpendicular to A is B*sinθ. Same principle is used in the above problem.
