Thread Closed
Griffiths E&M 3.33 write e-field of dipole moment in coordinate free form
Share Thread Thread Tools
Dec2-09, 08:11 PM   #1
Show that the electric field of a "pure" dipole can be written in the coordinate-free form
[tex]
E_{dip}(r)=\frac{1}{4\pi\epsilon_0}\frac{1}{r^3}[3(\vec p\cdot \hat r)\hat r-\vec p].[/tex]
2. Relevant equations
Starting from
[tex]E_{dip}(r)=\frac{p}{4\pi\epsilon_0r^3}(2\cos \hat r+\sin\theta \hat \theta)[/tex]
3. The attempt at a solution
The equation immediately above assumes a spherical coordinate system such that p is oriented along z. We can therefore write
[tex]\vec p=p\hat z[/tex]
[tex]\hat z = \cos\theta \hat r - \sin\theta \hat \theta \implies \vec p=p\cos\theta\hat r-p\sin\theta\hat\theta[/tex]
From equation 3.102 in the book we know that [itex]\hat r\cdot \vec p=p\cos\theta[/itex]
Try as I might I don't know how to show, geometrically or via manipulation, that [tex]p\sin\theta\hat \theta=(\vec p \cdot \hat \theta)\hat \theta[/tex]. From there it's easy to get to the desired result.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Dec2-09, 08:58 PM   #2
I find this problem is easier to see in reverse than forwards (that is, working from the solution to get the starting point)
[tex]
3(\mathbf{p}\cdot\hat{\mathbf{r}})\hat{\mathbf{r}}-\mathbf{p}=3p\cos\theta\hat{\mathbf{r}}-p\cos\theta\hat{\mathbf{r}}+p\sin\theta\hat{\boldsymbol{\theta}}=2p\cos \theta\hat{\mathbf{r}}+p\sin\theta\hat{\boldsymbol{\theta}}
[/tex]
which looks a lot like what you have in your relevant equations
Dec2-09, 09:16 PM   #3
Quote by jdwood983 View Post
[tex]
[/tex]
Well I guess that solves the problem. Seems a little anticlimactic. My professor recommended we draw a picture and show how things cancel out by dotting vectors together.
Dec2-09, 10:53 PM   #4
I was able to do it by using pictures...backwards. Here's how to derive the given equation from the desired equation.
Let theta be the polar angle and p point toward theta=0.
First draw the p vector and the r hat vector intersecting at some angle theta. Project p onto the r axis.
[tex]\overrightarrow{p}\cdot \widehat{r}=pcos(\Theta )[/tex]
Then draw the p vector (parallel to the original p vector) at some point at vector r from the origin (where the dipole is actually located). Resolve the p vector onto the (r, theta) coordinates.
[tex]
\widehat{p}=cos(\Theta )\widehat{r}+sin(\Theta )\left ( -\widehat{\Theta } \right )
[/tex]
Plugging those into the problem statement equation and doing some algebra gives you the equation you were supposed to start with. I'm sure you could just work through it backwards.
Dec3-09, 06:31 AM   #5
Quote by naele View Post
It is a little anticlimactic doing it backwards. I spent about 30 minutes trying to do the geometry forwards before I decided to do it backwards. When I saw the answer, my first thought was "That was it?"
As Jolb said, you can do it graphically if you draw the appropriate vectors, but I personally think it's easier to do it mathematically.
Thread Closed
Thread Tools
Similar Threads for: Griffiths E&M 3.33 write e-field of dipole moment in coordinate free form
Thread Forum Replies
Change in orbital magnetic dipole moment of the electron due to unifrom B field Introductory Physics Homework 0
Write the Magnetic Field of a dipole in coordinate-free form? Advanced Physics Homework 2
[SOLVED] Griffiths dipole moment Advanced Physics Homework 3
Induced dipole moment due to application of an external electric field to an atom Classical Physics 5
Magnetic Dipole Moment does not include the permeability of free space??? General Physics 6
