Heavy vs. Light Bungee Jumpers: Stored Energy Explained
Bungee jumpers should use shorter ropes if they are heavier, as the stored energy concept indicates that heavier jumpers experience greater strain energy due to their weight. The equations W=mg and strain energy = 1/2*k*x demonstrate that the force exerted by the jumper (F=mg) leads to a larger displacement (Delta x) for heavier individuals. This means that a longer rope would result in a higher risk of hitting the ground. Additionally, the assumption that the spring constant (k) remains constant across different rope lengths is incorrect; the effective k changes with rope length, similar to springs in series.
  • Understanding of basic physics concepts such as weight (W=mg) and strain energy.
  • Familiarity with Hooke's Law and spring constants (k).
  • Knowledge of energy conservation principles in mechanical systems.
  • Basic mathematical skills for manipulating equations.
  • Research the relationship between spring constants and rope length in elastic materials.
  • Explore the physics of energy conservation in bungee jumping scenarios.
  • Learn about the dynamics of elastic potential energy and its applications.
  • Investigate safety standards and recommendations for bungee jumping equipment.
Physics students, bungee jumping enthusiasts, and safety engineers interested in understanding the mechanics of bungee jumping and the implications of weight on rope selection.
Sam1234
Bungee jumpers use an elastic rope to halt their fall when they are just a short distance from the ground. Using the idea of stored energy, explain whether heavy jumpers should use a shorter or longer length of rope than lighter jumpers.
W=mg
The work here is done my the weight of the jumper. We have W=mg. Assume that k is constant for a rope, we have that F=mg=k*Delta x ==> Delta x is larger when m is larger, so the jumper might height the ground. He should use a shorter rope.
This is how i would answer the question, but it doesn't use the concept of stored energy and I was hoping someone could help me with that.
I don't think the assumption that k remains the same for the longer and shorter ropes is valid. If the ropes are identical in every respect except their length, then their effective k should differ, similar to the case of springs being attached in series.
