How long do metal and carbon film resistors last?
Metal film resistors outperform carbon film resistors due to their stability under heat and higher precision, with a typical variance of 1% compared to 5% for carbon films. Both types of resistors can fail, primarily as open circuits, influenced by environmental factors such as thermal and mechanical stress. Carbon film resistors are particularly susceptible to resistance drift and damage from excessive heat during soldering. In optimal conditions, resistors can last at least 15 years.
  • Understanding of resistor types: metal film and carbon film
  • Knowledge of resistor failure modes and environmental impacts
  • Familiarity with soldering techniques and their effects on components
  • Basic electronics principles related to component longevity
  • Research the thermal stability of metal film resistors
  • Explore the impact of humidity on resistor performance
  • Learn about resistor failure modes and prevention techniques
  • Investigate the longevity of different resistor types under various conditions
Electronics engineers, hobbyists, and anyone involved in circuit design and component selection, particularly those concerned with the longevity and reliability of resistors in high-frequency applications.
pseudoistor
Hello,
I've read that metal film resistors are better than carbon film because they're resistance remains constant even when they heat up from being soldered. And I know they're suppose to be more precise with a 1% variance instead of 5% of the carbon films.
I know capacitors go bad - do resistors? What is the shelf life of the carbon films and the metal films?
In your opinion, is it worth paying more for the metal films for the advantages? Specifically, for longer-term storage and being used in applications that use a high frequency.
Thanks
Seems like it's mostly a function of environmental factors: http://en.wikipedia.org/wiki/Resistor#Failure_modes
Like every part, resistors can fail in normal use. Thermal and mechanical stress, humidity, etc., can play a part. Carbon composition resistors and metal film resistors typically fail as open circuits. Carbon-film resistors may decrease or increase in resistance.[16] Carbon film and composition resistors can open if running close to their maximum dissipation. This is also possible but less likely with metal film and wirewound resistors. If not enclosed, wirewound resistors can corrode. The resistance of carbon composition resistors are prone to drift over time and are easily damaged by excessive heat in soldering (the binder evaporates). Variable resistors become electrically noisy as they wear.
All resistors can be destroyed, usually by going open-circuit, if subjected to excessive current due to failure of other components or accident.
I very much doubt that the average resistor won't make at least 15 years in the right conditions.
9K
  • · Replies 19 ·
11K
