Sum of two square and complex quadratic
The discussion focuses on two complex analysis problems: expressing 962 as a sum of two squares and finding a complex number 'a' such that the roots of the equation z² + az + 1 = 0 have equal absolute values. The solution to the first problem is definitively established as 962 = 11² + 29². For the second problem, participants highlight the complexity of dealing with complex coefficients and the limitations of using auxiliary equations, emphasizing the need for a more nuanced approach to find 'a'.
  • Understanding of complex numbers and their properties
  • Familiarity with Euler's Identity and polar coordinates
  • Knowledge of quadratic equations and their roots
  • Experience with sums of squares in number theory
  • Study the application of Euler's Identity in complex analysis
  • Learn about the polar representation of complex numbers
  • Explore methods for solving quadratic equations with complex coefficients
  • Research techniques for finding sums of squares in number theory
Mathematicians, students of complex analysis, and anyone interested in number theory and quadratic equations will benefit from this discussion.
r.a.c.
I actually have two questions, both are in the complex plane.
Q1: Express 962 as a sum of two squares (Hint: 962 = (13)(74)
Q2. Given z,a belong to C (complex). Find a such that the roots of the equation [tex]z^2 + az + 1 = 0[/tex] have equal absolute values (or modulus).
Well this is about the complex plane so for the first one I think most probably its Euler's Identity. As for the second it could be anything.
Q1: It is a sum of squares so the best I can think of is that 962 is a modulus of a vector i.e. z belongs to C, |z| = 962. Because z = a + ib so [tex]962^2 = a^2 + b^2[/tex]. Then I try writing z in polar so we have [tex]z = |z|e^i^x[/tex] , where x is the argument of z. But x = arctan b/a . So I somewhat got stuck in a loop.
Q2: We can't use the auxiliary equation because a is also complex. So it doesn't work. I tried expanding both z and a only to get stuck eventually in an overly complicated equation. Any suggestions on just how to start it?
The problem asks you to find a and b such that [itex]a^2+ b^2= 962[/itex], NOT [itex]962^2[/itex]! Although it doesn't have anything to do with this hint, one way to do it is by "brute strength": Is 962- 1 a square? 962- 4? 962- 9?...
I have no idea what you mean by this. What "auxiliary equation? And the real numbers are a subset of the complex numbers- saying that "a is a complex number" doesn't mean it can't be real. There is an obvious real number solution for a.
The auxiliary equation is [tex]x = \frac{-b \frac{+}{-} \sqrt{4ac - b^2}}{2a}[/tex] where [tex]ax^2+bx+c=0[/tex]. That's what I know it as anyways. Anyways, even the teacher said you can't do it that way. But if you can find a way, then I'd be more than happy.
You're right, I'm not saying a can't be real, but we also cannot make the assumption that it is purely real or imaginary. Why is there an obvious real number solution?
As for the sum of squares: I tried by brute strength, which did work, but its time consuming and has nothing to do with the hint or what we're studying. It turned out to be [tex]962 = 11^2+29^2[/tex].
  • · Replies 26 ·
