Square integrable functions blowing up at infinity
The discussion revolves around the nature of square integrable functions in quantum mechanics, particularly those that exhibit pathological behavior, such as blowing up at infinity. Participants explore the implications of these functions for physical realizability, the requirements for wave functions, and the conditions under which certain mathematical properties hold.
  • Some participants question the physical realizability of square integrable functions that blow up at infinity, referencing Griffiths' statements on wave functions.
  • There is a discussion on the definition of functions blowing up at infinity, with clarifications on limits and integrability properties.
  • One participant mentions that the wave function must be square integrable for the probability interpretation to hold, and highlights an example of a square integrable function that does not approach zero at infinity.
  • Another participant argues that differentiability is a requirement for solutions of the Schrödinger equation, suggesting that non-differentiable functions cannot be physical.
  • There are suggestions that piece-wise differentiable functions might still be valid in certain contexts, such as infinite potential wells.
  • Participants discuss the possibility of constructing continuous and smooth versions of functions that maintain square integrability while varying their shapes and properties.
  • One participant notes that while a function can be square integrable and unbounded, it does not necessarily imply that it approaches infinity as x goes to infinity.
  • Another participant raises a question about Griffiths' assertion regarding the behavior of wave functions at infinity.
  • An example involving position eigenstates and their limits at infinity is provided to illustrate the complexities involved.
Participants express differing views on the implications of square integrable functions and their physical realizability. There is no consensus on the validity of certain functions or the interpretation of Griffiths' statements, leading to ongoing debate and exploration of the topic.
Limitations include the dependence on definitions of integrability and differentiability, as well as the unresolved nature of certain mathematical properties related to the functions discussed.
kof9595995
I've been reading Griffths QM recently, and in the book he mentioned a couple of times that though these pathological functions exist, they're not physically realizable. But what's wrong with these functions? What prevents them to be physically realizable ?
EDIT:Griffths' statement is wave function may not vanish at infinity, not blow up; Thanks to George Jones pointing out.
This is not exactly what Griffiths states.
By blowing up at infinity, do you mean a real-valued function [itex]f[/itex] of a real variable such that
[tex]\lim_{x \rightarrow \infty} f \left( x \right) = \infty?[/tex]
More precisely, this means that for every [itex]L > 0[/itex], there exists an [itex]x_0 > 0[/itex] with [itex]f \left( x \right) > L[/itex] whenever [itex]x > x_0.[/itex]
Using this property, it is fairly easy to show that [itex]\left| f \left( x \right) \right|^2[/itex] is a positive function that blows up at infinity, and that any positive function with this property is not integrable.
Or do you mean for every [itex]L > 0[/itex], there exists an [itex]x_0 > 0[/itex] with [itex]f \left( x \right) > L[/itex] for some [itex]x > x_0[/itex]?
There are lots of square-integrable functions with this property. For example, consider the real-valued function of a real variable that is zero except when [itex]x[/itex] is a rational number, and has [itex]f \left( x \right) = x[/itex] when [itex]x[/itex] is a rational number. Then, [itex]\left| f \left( x \right) \right|^2[/itex] integrates to zero. The function in this example is actually (a representative of) the zero vector in Hilbert space, since it differs from the zero function only on a set of measure zero,
Adding to what George said: The reason why the wavefunction must be square integrable is that the probability interpretation doesn't work if it isn't.
Hurkyl showed me an interesting example of a square integrable function that doesn't even go to zero as x goes to infinty. Link. Those functions aren't physical because a solution of the Schrödinger equation must be differentiable (and all differentiable functions are continuous).
Yeah you're right, i recheck the book and he only stated that as x goes to infinity f(x) doesn't vanish, and meanwhile it's square integrable.
Really nice example, and you said it's not valid because it's not differentiable. But isn't it piece-wise differentiable? When we encounter a infinite potential somewhere it seems piece-wise differentiable is enough, like infinite square well or delta function potential.
There are continuous, differentiable, and even smooth versions of such functions; you just replace the basic rectangle shape
[tex] f(x) = \begin{cases} 0 & x < 0 \\<br /> 1 & 0 \leq x < 1 \\<br /> 0 & 1 \leq x \end{cases}[/tex]​
with something smoother.
And if we just have the width of those shapes decrease more rapidly, we can let their height increase instead of being constant. Now I'm confused again.
However, this doesn't contradict George's earlier assertion -- while such a function is square integrable and unbounded, we do not have [itex]\lim_{x \to +\infty} f(x) = +\infty[/itex] -- the limit at infinity simply doesn't exist.
So Hurkyl, what's your comment on Griffiths' statement, e.g., psi(x) always goes to 0 at infinity in reality?
I'm not qualified to comment.
Example:
|s> = 6/pi^2 sum over n = 1 to infinity of 1/n |x_n>
Where the |x_n> are position eigenstates that you can replace by smooth normalized states with peak at x_n and with compact support. If the x_n tend to infinity, then the limit of
psi(x) = <x|s> for x to infinity does not exist.
  • · Replies 75 ·
  • · Replies 59 ·
  • · Replies 24 ·
