Proving Triangular Matrix Inverse is Also Triangular
  • Context: Undergrad
  • Thread starter Thread starter crd
    Matrices
The inverse of a triangular matrix is indeed triangular, as established through induction and row operations. For an invertible upper triangular matrix A, the product AA^{-1} equals the identity matrix I, confirming that the entries of A^{-1} maintain the triangular structure. Specifically, the last row of A multiplied by the last column of A^{-1} yields the identity's last entry, while subsequent rows ensure that non-diagonal entries remain zero. This proof elegantly demonstrates the triangular nature of the inverse without relying solely on brute force methods.
  • Understanding of triangular matrices in linear algebra
  • Familiarity with matrix operations and properties
  • Knowledge of mathematical induction techniques
  • Experience with identity matrices and their significance
  • Study the properties of triangular matrices in linear algebra
  • Learn about mathematical induction and its applications in proofs
  • Explore matrix operations, focusing on row reduction techniques
  • Investigate the implications of matrix inverses in various contexts
Students and professionals in mathematics, particularly those studying linear algebra, as well as educators seeking to deepen their understanding of matrix properties and proofs.
crd
It is stated in almost every linear algebra text i could find that the inverse of a triangular matrix is also triangular, but no proofs accompanied such statements.
I am convinced that it is the truth, but I have not been able to write anything down that I am satisfied with that doesn't rely on the argument that row operations on the matrix (A|I) to obtain (I|A^{-1}).
Since this would only be the forward pass(if A is lower triangular) and the backwards pass(if A is upper triangular) and these operations ultimately do not introduce non zero terms above/below the diagonal entries(depending on what A was), thus A^{-1} would be a triangular matrix of the same flavor.
Has anyone come across anything a little more elegant than simply brute forcing it?
Assume you have a invertible upper triangular matrix. Consider
[tex]AA^{-1} = I[/tex]
You can use induction, starting from the last row of A times the last column of [itex]A^{-1}[/itex]. gives you the entry. lower left entry 1.
Then again take the last row of A and n-1 column of [itex]A^{-1}[/itex]. To be able to get a zero in the identity matrix, (n,n-1) entry of [itex]A^{-1}[/itex] must be zero.
Carry on to the upper left corner and you are done.
9K
  • · Replies 21 ·
12K
