Rotating object angular velocity question
The discussion revolves around a problem involving the angular velocity of a rotating object, specifically calculating the total angle rotated in both radians and degrees after one minute, given an angular velocity of 10 radians per second.
  • Participants explore different calculations for the angle rotated, with some attempting to convert radians to degrees and questioning the validity of their results.
There are multiple interpretations of the calculations being discussed, with participants providing various methods and questioning the results. Some guidance has been offered regarding the conversion between radians and degrees, but no consensus has been reached on the correct answer.
Participants express confusion regarding the calculations and the results, indicating a need for clarification on the relationships between angular velocity, time, and angle rotation.
pinnacleprouk
A rotating object has angular velocity 10radians/s. After one min through what angle has the object rotated in 1) radians 2) degrees
Degrees = Radians x 180/Pi
I have tried and only come up with an answer of 3600 which i know is wrong
3600 what?
Any help is appreciated
Thanks in advance!
(rad/s)*(s)= radians
also, 1 min = 60 s.
So are we saying that 10*60 = 600 radians
Therefore 6.00 = d x Pi/180
6.00 = d x 0.0175
6.00/0.0175 = d
d = 343 degrees?
or is it... θ = (w0 + w)t/2
θ = (0+10) x 60/2
θ = 300 Degrees?
Thanks in advance
and π radians is 180°
so 600 radians is?
How can it be 600 radians that does not make sense! I am sorry but I don't understand
10 radians/s
in 1 s, object rotates 10 radians
in 60s...
so would the answer to the original question be
1) 600 Radians
2) 34377 Degrees
Thanks in advance
  • · Replies 32 ·
  • · Replies 35 ·
  • · Replies 39 ·
