3 pin vs 2 pin power plug
by likephysics
Tags: plug, power
likephysics
likephysics is offline
#1
Dec10-09, 12:10 AM
P: 596
I was looking at my laptop power plug - one has a 3 pin and the other is 2 pin.
The power coming into the laptop has only 2 connections - GND and +DC
If I remember rectifiers, we only used the AC mains to convert AC to DC, not the earth.
I am wondering, where is the the earth pin connected in the laptop power converter? To the power converter chassis?
Phys.Org News Partner Engineering news on Phys.org
PsiKick's batteryless sensors poised for coming 'Internet of things'
Researcher launches successful tech start-up to help the blind
Researchers propose network-based evaluation tool to assess relief operations feasibility
sophiecentaur
sophiecentaur is online now
#2
Dec10-09, 08:25 AM
Sci Advisor
PF Gold
sophiecentaur's Avatar
P: 11,352
It may not be connected to anything. Most power supples are double insulated, in any case and often have a plastic third pin. (UK)
mgb_phys
mgb_phys is offline
#3
Dec10-09, 10:20 AM
Sci Advisor
HW Helper
P: 8,961
Th plastic earth pin is there because it is needed to lift the safety shutters on the live+neutral pins on a UK socket.
sophiecentaur
#4
Dec10-09, 10:24 AM
Sci Advisor
PF Gold
P: 11,352
Natch.
I meant that the third pin is plastic rather than brass.
mgb_phys
mgb_phys is offline
#5
Dec10-09, 10:28 AM
Sci Advisor
HW Helper
P: 8,961
I was just explaining why they bother fitting a 3rd pin if it's plastic - other than BS1363 requiring it
likephysics
#6
Dec10-09, 12:24 PM
P: 596
The 3rd pin is not plastic. It is metal, just like the two other pins. The laptop was bought in the USA.
vk6kro
vk6kro is offline
#7
Dec10-09, 05:51 PM
Sci Advisor
P: 4,003
Quote Quote by likephysics View Post
Are you referring to the external power supply that converts your mains AC to about 17 volts DC for the laptop?
Mine is a switch mode power supply and it is in an earthed metal case, possibly to reduce radiated interference. The negative lead of the 17 V DC is also earthed, but the laptop would still function if it wasn't earthed.
These power supplies contain high frequency oscillators that generate a lot of harmonics and these need to be filtered and shielded to avoid interference in nearby equipment.
mgb_phys
mgb_phys is offline
#8
Dec10-09, 06:43 PM
Sci Advisor
HW Helper
P: 8,961
Sorry got a bit off topic.
The earth pin is a saefty feature, any exposed metal parts of a product must be connected to earth so that if a fault allowed the live wire to touch the metal your would be protected. Since the laptop isn't made of metal - and doesn't have any high voltages inside it there is no need of an earth.
The power brick probably has a 2 pin connection (a figure of 8 DIN socket) because it is also plastic and doesn't need an Earth.
UK plugs always have an earth because the third pin is needed to open the safety shutters on the live/neutral holes, if the equipement doesnt need the earth this pin is sometimes plastic to save money - but an unused metal earth pin isn't a problem.
US plugs that connect to non-earthed applicances can be just two pins.
If the laptop power brick has a 3pin socket then its a bit naughty to supply a 2pin plug .
likephysics
#9
Dec11-09, 03:07 AM
P: 596
Quote Quote by vk6kro View Post
That's what I thought. But I don't think there is a metal case, only plastic outer case. which is why the confusion started. Maybe some of the power converters have them.
vk6kro
vk6kro is offline
#10
Dec11-09, 08:27 AM
Sci Advisor
P: 4,003
Mine has a plastic case, but it seems to have a metal inner casing which might be for EM shielding. I can attract it weakly with a magnet, but I haven't taken it to bits.
If so, it would need to be earthed.
On the outer plastic there is a caution: "connect only to a grounded outlet". Since there is no exposed metal, this would be for the shielding to be effective.
Also, there would be filtering on the input and this would have capacitors bypassing the input lines to ground. So, the ground would have to be brought into the box.
Mine has 8nF from both active and neutral input leads to the ground lead and this is presumably from filtering at the input of the power supply.
Register to reply
Related Discussions
Electric Cars, plug-ins? Why not CNG? Current Events 8
Spinning down the plug hole General Physics 5
Lost plug General Discussion 24
What the! isn't this plug and chug? Introductory Physics Homework 4
wireless and adapter plug Computing & Technology 2
