Find Range of Ray Emitted Horizontally at Depth 150m in Water
  • Thread starter Thread starter yemmdizzle006
    Sound Speed
The problem involves calculating the horizontal range of a sound ray emitted from a depth of 150 meters in water, where the speed of sound is 1600 m/s at the surface and increases linearly at a rate of 0.017 m/s². The correct formula to determine the horizontal range (x) is derived from the curvature of the ray, given by x = sqrt((2 * c * d) / g). Using this formula, the correct horizontal range is found to be 4200 meters, contrasting with an incorrect initial calculation of 883880 meters.
  • Understanding of sound propagation in fluids
  • Familiarity with calculus concepts related to gradients
  • Knowledge of the physics of waves and ray theory
  • Ability to manipulate and solve equations involving square roots
  • Study the derivation of the formula x = sqrt((2 * c * d) / g) in detail
  • Learn about the effects of temperature and pressure on sound speed in water
  • Explore ray theory in acoustics for further applications
  • Investigate numerical methods for solving complex wave propagation problems
Students studying physics, particularly in acoustics and fluid dynamics, as well as educators looking for practical examples of sound propagation in water.
yemmdizzle006
speed of sound in water is 1600m/s at the surface and increases linearly with depth at a rate of 0.017/s, find the range at which a ray emitted horizontally at a source of dept 150m will reach the surface
C = sound speed in water (1500m/s)
gradient = g (0.017/s)
Relevant equations I used will be calculate the Radius of the curvature of the Ray
R (curvature of Ray) = c0/g
I keep getting a huge figure 883880m ...
and i know it is not correct.
apparently the answer is that at 4200m, the ray emitted horizontally will reach the surface.I have no idea how my teacher came up with that.Is there some piece of information I am missing?
solution
x = horizontal range
c = speed of sound
d = depth
g = gradient
x = sqrt( (2*c*d) / g))
Thank you!
9K
