How Is Angular Frequency Calculated for a Plank Supported by a Spring?
The angular frequency of small oscillations for a uniform plank of mass 2.0 kg and length 1.0 m, pivoted at one end and supported by a spring with a spring constant (k) of 1000 N/m, is calculated to be 39 s-1. The moment of inertia (I) for the plank is determined using the formula I = (1/3) * M * (L2), where M is the mass and L is the length. The period (T) of oscillation is derived from the equation T = 2π√(I/mgr), where r is the distance from the center of mass. The frequency (f) is then obtained by taking the inverse of the period.
  • Understanding of angular frequency and oscillations
  • Familiarity with the moment of inertia formula for a uniform rod
  • Knowledge of spring constants and Hooke's Law
  • Basic principles of rotational dynamics
  • Study the derivation of angular frequency in oscillatory systems
  • Learn about the moment of inertia for various shapes and its applications
  • Explore the relationship between spring constants and oscillation frequency
  • Investigate the effects of pivot points on the dynamics of oscillating bodies
Physics students, mechanical engineers, and anyone interested in the dynamics of oscillating systems and spring mechanics.
kkred
A uniform plank of mass 2.0kg and length 1.0m is pivoted at one end
in a horizontal plane. It is supported at the other end by a spring with
k = 1000 N/m . What is the angular frequency of small oscillations? It m
may interest you to know that the moment of inertia of a uniform rod about its end is 1/3*M(L^2) where M is the mass and L is the length.
Tried to find Angular frequency by using angular momentum but I didn't find a suitable way to do it. Any suggestions?
The answer is 39s^-1
use T=(2*3.14(I/mgr)^(1/2))
r is the distance from center of mass
Then inverse T to calculate the value of f.
18K
