Kinetic energy and normal force
The discussion centers on a physics problem involving kinetic energy and normal force for a sled with a mass of 100 kg sliding down a frictionless incline of 20 degrees. The kinetic energy at the bottom is determined using the conservation of energy principle rather than calculating speed directly. The normal force is defined as the component of gravitational force perpendicular to the slope, calculated using the formula mgcos(θ). The net acceleration is confirmed to be the sum of all forces divided by mass, although the term "net acceleration" is debated among participants.
  • Understanding of kinetic energy and the formula KE=(1/2)mv^2
  • Knowledge of gravitational force and its components on inclined planes
  • Familiarity with Newton's second law of motion
  • Basic principles of conservation of energy in physics
  • Review conservation of energy principles in physics
  • Study the calculation of normal force on inclined planes
  • Learn about the effects of friction on motion and energy
  • Explore advanced topics in dynamics, such as net forces and acceleration
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of energy conservation and forces on inclined surfaces.
Rowie25
You and your sled have a mass of 100 kg and starting from rest, slide down a very icy and frictionless road which is 20 degrees steep and 200 m long.
a. What is your kinetic energy at the bottom of the hill?
b. What is your net acceleration?
c. How long does it take you to slide to the bottom?
d. What is the normal force exerted on you and your sled?
At the bottom of the hill you change direction but not your speed and go up a hill which is 30 degrees steep and with friction coefficient .1.
e. What distance along the hill do you go before stopping?
I am not sure how to start this one. I think you have to find the speed first since KE=(1/2)mv^2. I think normal force is mgcos(angle)yhat but I don't know how to find yhat. Also is net acceleration the sum of all forces divided by the mass? I'm stuck!
Speed is not needed, this is a conservation-of-energy question. You can check your textbook for the relevant equation if you do not know it.
It's universally agreed that the normal force's direction is perpendicular to the sloping surface (by definition), so it should suffice to give it's magnitude.
Yes, that is what they are asking for. Personally I dislike the term "net acceleration", an object only has one acceleration even if there are several forces acting on it. Just my opinion.
Ohh okay thank you! I'll work on it!
  • · Replies 21 ·
