What is the Derivative of an Integral with a Variable Limit?
The discussion revolves around finding the derivative of a function defined by a definite integral with a variable upper limit. The function in question is F(x) = ∫_{+\infty}^{x^2} e^{-xt^2} dt, which raises questions about the treatment of the variable x within the integral.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the application of the Leibniz integral rule for differentiating under the integral sign. There are attempts to separate the variable x from the integral and discussions about the implications of the limits of integration. Some participants express confusion regarding the presence of e^{-x} within the integral and how it affects the differentiation process.
The discussion is active, with participants sharing various approaches and clarifications regarding the differentiation of the integral. Some have provided insights into using integration by parts and the chain rule, while others are questioning the assumptions about the limits of integration and the behavior of the integral as t approaches infinity.
One participant notes that this is not a homework question but rather a review of calculus concepts in preparation for further studies. There is an ongoing examination of the appropriateness of using +infinity as a limit in the context of the integral.
cappadonza
hey I'm having problems trying to find the derivative of the function
i'm not sure how the separate the x out of the integral
i want to find the derivative of F(x) where
[tex]F(x) = \int_{+\infty}^{x^2} e^{-xt^2} dt[/tex]
thanks
Let
[tex]P(x) = \int e^{-xt^2} \textrm{ d}t[/tex]
(with arbitrary constant)
Then you probably know how to find P'(x), but the hard part is finding
[tex]\frac{dP(x^2)}{dx}[/tex]
Let s be the squaring function (i.e. let s(x) = x^2), then what you want to find is:
[tex]\frac{d(P\circ s)(x)}{dx}[[/tex]
which you can find using the chain-rule, and then you just do:
[tex]F'(x) = \frac{dP(x^2)}{dx} - \left(\lim_{t \to +\infty} P(t)\right)'[/tex]
Thanks i did do it the way you suggested but what confused me is that there is an e^-x
under the integral. I was trying to find a way to it in a form so that only t was under the integral.
For example when
i had
[tex]F(x) = \int e^{-(x +t)} dt[/tex]
i got it into the following form
[tex]F(x) = e^-x \int e^-t dt[/tex]
from here i use the product rule to find the derivative of F(x).
I thought i would have had to do something similar to move
[tex]e^{-x}[/tex]
outside the integral. or doesn't it matter in this case since i can treat as a constant in the power
thanks
thanks
The general rule for taking the derivative of a definite integral is the Leibiz integral rule:
[tex]\frac d{dx}\int_{a(x)}^{b(x)} f(x,t) dt =<br /> \frac{db(x)}{dx} f(x,b(x)) \,-\, \frac{da(x)}{dx} f(x,a(x)) \,+\,<br /> \int_{a(x)}^{b(x)} \frac{\partial f(x,t)}{\partial x} dt[/tex]
Applying that rule to this specific problem is not all that tough. (Is this homework?)BTW, did you really mean to use +infinity for the lower limit on your integral?
Thanks
no this not a homework question, its been many years since my first degree, I'm basically going through basic calculus notes to get ready for my post graduate course in mathematics in finance.
i did mean to use +infinity, since the exponential is to the - ve power, this shouldn't be a problem since this will tend to 0 as t-> infinity. does this make sense or am i missing something
Since this is not homework, applying the Leibniz integral rule to this particular integral yields
[tex] \frac {dF(x)}{dx} = \frac d{dx}\int_{\infty}^{x^2} e^{-xt^2}\,dt<br /> = 2x e^{-x^3} - \int_{\infty}^{x^2} t^2e^{-xt^2}\,dt \qquad\qqaud (1)[/tex]
That integral on the right-hand side can be re-expressed in terms of the original integral. The easiest way is to integrate the original integral, [itex]F(x)=\int \exp(-xt^2)\,dt[/itex], by parts:
[tex]\aligned<br /> u &= e^{-xt^2} & du &= -2xte^{-xt^2}\,dt \\<br /> dv &= dt & v &= t\endaligned[/tex]
Integrating by parts,
[tex] \int e^{-xt^2}\,dt = te^{-xt^2} + 2x\int t^2 e^{-xt^2}\,dt[/tex]
or
[tex] \int t^2 e^{-xt^2}\,dt = \frac 1{2x}\left(\int e^{-xt^2}\,dt - te^{-xt^2}\right)[/tex]
Applying this in (1) yields (assuming I didn't make a dumb mistake somewhere),
[tex]\aligned<br /> \frac {dF(x)}{dx}<br /> &= 2x e^{-x^3} -<br /> \frac 1{2x}<br /> \left(<br /> \int_{\infty}^{x^2} e^{-xt^2}\,dt -<br /> \left(\left. t e^{-xt^2}\right|_{t=\infty}^{x^2}\right)<br /> \right)<br /> &= \frac 5 2\,x e^{-x^3} - \frac {F(x)}{2x}[/tex]
Thanks makes a lot of sense
  • · Replies 23 ·
  • · Replies 16 ·
