Maginutude and Phase Angle for Nyquist Plots
The discussion focuses on deriving the magnitude and phase angle for the Nyquist Plot of the transfer function G(s) = k(s+2)/((s+1)(s-3)). The magnitude is calculated as |G(jω)| = k√(ω²+4)/√(ω²+1)√(ω²+9). The phase angle is determined using the formula ∠G(jω) = tan⁻¹(ω/2) - tan⁻¹(ω/1) - (180 - tan⁻¹(ω/3)), where the 180° shift accounts for the direction of the vector (jω - 3) in the complex plane.
  • Understanding of transfer functions in control systems
  • Familiarity with complex numbers and their representation
  • Knowledge of Nyquist stability criterion
  • Proficiency in calculating magnitude and phase of complex functions
  • Study the Nyquist stability criterion in detail
  • Learn about the implications of phase shifts in control systems
  • Explore the use of MATLAB for plotting Nyquist diagrams
  • Investigate the significance of poles and zeros in transfer functions
Control system engineers, electrical engineers, and students studying control theory who need to understand Nyquist Plots and their implications in system stability.
EugP
Magnitude and Phase Angle for Nyquist Plots
The assignment is to draw a Nyquist Plot of a certain transfer function. The problem is that I can't figure out how they got the angle for the plot.
[itex] <br /> G(s) = \frac{k(s+2)}{(s+1)(s-3)}<br /> [/itex]
[itex] <br /> |G(j\omega)| \angle G(j\omega)<br /> [/itex]
[itex] <br /> G(j\omega) = \frac{k(j\omega+2)}{(j\omega+1)(j\omega-3)}<br /> <br /> [/itex]
From that I know that the magnitude is found like this:
[itex] <br /> |G(j\omega)| = \frac{k\sqrt{(\omega^2+4)}}{\sqrt{(\omega^2+1)}\sqrt{(\omega^2+9)}}<br /> [/itex]
Now, the solution says that the phase angle is:
[itex] <br /> \angle G(j\omega) = \angle \tan ^{-1} (\frac{\omega}{2})-\tan ^{-1} (\frac{\omega}{1})-(180 - \tan ^{-1} (\frac{\omega}{3}))<br /> [/itex]
What I don't understand is why there is a [itex]180^o[/itex] shift in the last term.
Any help would be greatly appreciated.
If you consider (jw-3) alone, its y coordinate is 'w' and its x coordinate is '-3'.
Thus (jw-3) as a directed vector from the origin makes an angle of 180-tan-1(w/3) with the positive x axis.
The angle with the positive x-axis is to be considered, not just tan-1(y/x).
9K
