Light & Relativity: 2 Questions Answered
  • Context: Graduate
  • Thread starter Thread starter Dragohunter
    Light Relativity
This discussion addresses two fundamental questions regarding light and relativity. Firstly, light does not possess a frame of reference that moves along with it, as the gamma factor linking such a frame to any material object would be infinite. Secondly, while no object can exceed the speed of light (c) relative to an observer, distant objects can appear to recede from the observer at speeds greater than c, particularly in the context of galaxies beyond the observable universe.
  • Understanding of special relativity principles
  • Familiarity with the concept of the gamma factor
  • Knowledge of inertial reference frames
  • Basic comprehension of cosmic expansion and observable universe limits
  • Study the implications of the gamma factor in special relativity
  • Explore the concept of inertial reference frames in detail
  • Investigate the phenomenon of cosmic expansion and its effects on distant galaxies
  • Learn about the limitations of observation in cosmology
Physicists, students of relativity, and anyone interested in the fundamental principles of light and cosmic phenomena will benefit from this discussion.
Dragohunter
2 questions
Does light have a frame of reference?
Although there is no speed greater than c, can it be said that the change in distance between two identifiable objects changed at a rate greater than c?
For example one person I know said this:
If you are able to do any simple example in special relativity, you will be able to verify this very easily for yourself. Just look at the distance between two photons moving in opposite directions in an arbitrary inertial reference frame.
Are you asking whether it's possible to have a frame of reference that's moving along with a beam of light? If so, then the answer is no. For example, the [itex]\gamma[/itex] factor linking this frame to the frame of any material object would be infinite.
For example one person I know said this: "If you are able to do any simple example in special relativity, you will be able to verify this very easily for yourself. Just look at the distance between two photons moving in opposite directions in an arbitrary inertial reference frame."
Your friend is correct. What's forbidden by relativity is much more specific. For example, suppose you have an observer who takes measurements in a certain reference frame. Relativity forbids a particle from whizzing right past the observer's location at a speed greater than c. It doesn't forbid distant objects from moving at greater than c relative to the observer. For example, you can say that galaxies beyond the edge of the observable universe are moving away from us at greater than c; however, it's impossible for us to observe those galaxies.
  • · Replies 33 ·
  • · Replies 74 ·
  • · Replies 67 ·
  • · Replies 221 ·
18K
  • · Replies 57 ·
  • · Replies 34 ·
  • · Replies 16 ·
