Thread Closed
Who knows the proper name for this experiment...
Share Thread Thread Tools
Dec14-09, 04:44 AM   #1
Hi,
I read about an experiment in which less energy than expected was required to restart a motor that had already been spinning. The explanation i read indicated that there was some sort of 'magnetic-sensitive ether' that continued to rotate after the motor had stopped, meaning that restarting it in the same direction could take advantage of the ether's momentum.
Your wisdom is greatly appreciated :-)
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Dec14-09, 02:45 PM   #2
You'll get more replies if you clarify your question...
Dec14-09, 02:56 PM   #3
Quote by Neo_Anderson View Post
Ok i'll give it another shot!
I read about an experiment in which a motor was speed up to a high speed, then forced to stop. If the motor was then restarted within, say, 30 seconds, the amount of energy required to get the motor up to full speed was less than when it was first brought up to full speed.
The article metioned that some sort of rotating field that continued to move, eventhough the motor was stationary (as if the field had its own momentum that was loosely coupled to the rotational motion of the motor).
What is the name of this experiment?
thanks again.
Dec15-09, 05:22 AM   #4
Quote by rimblock View Post
thanks again.
Someone must know!
Dec16-09, 06:28 PM   #5
I'm not sure of the name of the experiment in question, but I would have to assume any difference in restart amperage would be due to residual magnetism. Possibly the coefficient of friction of warm bearings vs. cold ones too. I'd be interested in the actual experimental results if you ever find them. I have to assume it is a very small difference.
Dec18-09, 06:14 AM   #6
Quote by denni89627 View Post
Somebody must know! I'm sure i wasn't sleep reading..!
Dec18-09, 06:23 AM   #7
Mentor
The correct name for the experiment is "hoax" if the experimenter knows his conclusions are wrong or "pseudoscience" if the experimenter believes his conclusions and simply performed a bad experiment.
Dec18-09, 06:31 AM   #8
Quote by DaleSpam View Post
Seriously, not a hoax afaik. I wish i could remember the name. That said if there are any genies reading this, i have other priorties so PM me.
Dec19-09, 08:25 AM   #9
Anyone?
I have been looking for days now!
I am sure it wasn't a hoax because i found other articles describing the same effect.
Dec19-09, 08:38 AM   #10
Mentor
Then it is pseudoscience and they are not carefully controlling their sources of experimental errors. There is no reputable evidence for a luminiferous aether, let alone one that can carry momentum.
Give up this pointless search and apply your time to learning some real science instead. Whether it is a hoax or pseudoscience, either way you are chasing a fairy tale.
Dec20-09, 02:44 PM   #11
Hey, thanks for your response. Congrats on 4000 posts too!
I looked up 'luminiferous aether motor' on google and couldn't find any reference to the experiment i described. Perhaps my explanation is incorrect(!), but i am sure i read a few articles that supported the same result ... 'that a motor restarted before a certain time required less energy to reach full speed'. Aether aside, does this result ring any bells? The energy saving was definitely not down to warm bearings or any other obvious reason.
Also, i was only asking for the name of an experiment. Failing to answer my question, accompanied with a short lecture telling me i need to learn some 'real science', when you know nothing about me (or the experiment i was refering to), kind of makes me think you are prone to missing important information and making rash assumptions.
Cheers.
Thread Closed
Tags
experiment, motor
Thread Tools
Similar Threads for: Who knows the proper name for this experiment...
Thread Forum Replies
proper velocity Advanced Physics Homework 7
proper time or proper time interval Special & General Relativity 3
Re: Proper Frequency General Physics 0
what is the proper name for H? Classical Physics 4
