Your opinion as to what homolgy is
  • Thread starter Thread starter farful
The term "homologous" is primarily qualitative, indicating that two sequences derive from a common ancestral sequence. In the discussion, it is emphasized that while statements like "Sequence A is 95% homologous to Sequence B" are commonly used, they can lead to ambiguity between sequence identity and sequence similarity. The distinction is crucial, as sequence identity refers to exact matches in amino acids, while sequence similarity considers chemical properties. Professors advocate for a binary understanding of homology, asserting that two sequences are either homologous or not, rather than discussing degrees of homology.
  • Understanding of sequence identity and sequence similarity
  • Familiarity with the concepts of orthology and paralogy
  • Basic knowledge of genetic sequences and their evolution
  • Awareness of gene shuffling and its implications
  • Research the definitions and differences between sequence identity and sequence similarity
  • Study the roles of orthologous and paralogous genes in evolutionary biology
  • Explore gene shuffling mechanisms and their effects on sequence homology
  • Examine literature on best practices for discussing homology in scientific writing
Biologists, geneticists, and bioinformaticians who are involved in sequence analysis and evolutionary studies will benefit from this discussion.
farful
In your opinion, do you think the word "homologous" is quantitative or qualitative?
That is, if I said "Sequence A is 95% homologous to sequence B!" would that be a correct or incorrect usage of the term?
Biology news on Phys.org
I think that the word homology is more of a qualitative term. Basically, if two sequences are homologous, they derived from a common ancestral sequence. You could split homology into two categories: paralogy and orthology. Orthologous genes are genes that play the same role in different organisms whereas paralogous genes are genes that derive from the a common ancestor but have diverged in function.
A statement like "sequence A is 95% homologous to sequence B" is commonly used and it could be considered correct. It can be somewhat ambiguous because there is a distinction between sequence identity (i.e. regions where sequence A and sequence B code for exactly the same amino acids) and sequence similarity (i.e. regions where sequence A and sequence B code for amino acids with the same chemical properties). Sequence homology is usually interpreted to mean the latter, though it would be better to specify whether one is looking at sequence similarity or sequence identity.
I think it is better to use phrases such as "The sequences are x% identical indicating that they are homologous", alternatively "x% similar under y scoring scheme". In undergraduate courses at my university the professors are very keen to stress that it is not sensible to talk about degrees of homology, and urge us to use this term as a strictly binary label: two entities are either homologous or not. They (the professors) also tend to apologize that some of the available literature is written without proper regard to this.
Because of gene shuffling it might make sense to talk about partial homology in the sense that z% of a sequence is shown to be significantly similar to some other sequence, suggesting that a subsequence of a sequence is homologous to some part of another sequence, while the rest of the sequence is not (or at least is more distantly related).
  • · Replies 24 ·
  • · Replies 25 ·
  • · Replies 27 ·
  • · Replies 20 ·
