| New Reply |
Tapered beam deflection problem |
Share Thread | Thread Tools |
| Dec15-09, 03:24 PM | #1 |
Hello everybody! So I have this beam beading problem I've been trying to figure out, (this is not a homework assignment) maybe someone can help. I have this beam that has a load at the midpoint. It's being simple supported on both ends and it's height tapers along it length on both sides. The base remains constant. I have experimental data on the max deflection at the midpoint, Force applied at midpoint and I'm looking for the experimental Young's Modulus (E) of the material. My first though was to apply d2y/dx2 =-M/EI => ymax =(-M/EI)dxdx. but I'm getting lost.. Can someone help?
Thanks, Nauen |
| Dec17-09, 01:58 PM | #2 |
Recognitions:
nauen: You're almost there. Deflection y = (1/E)*integral[integral{[M(x)/I(x)]*dx}*dx], integrated from x = 0 to 0.5*L.
| Dec18-09, 02:38 PM | #3 |
Can I do it that way because this a tapered beam the bending is not going to be symmetrical? Will the equation still hold?
| Dec19-09, 09:21 AM | #4 |
Recognitions:
Are the left and right sides of your beam symmetrical about a vertical axis passing through the beam midpoint?
| Dec19-09, 09:57 AM | #5 |
I attached a image showing the problem. So the beam is symmetrical about the y axis and tapered about the x axis. Because of this i would assume that the area with a smaller h would bend more. Since i have a force and a deflection at yc, would that change the way I construct my equation to find the E value.
Thanks |
| Dec20-09, 02:27 PM | #6 |
Recognitions:
nauen: The midspan deflection would be as follows. I(x) means I is a function of x. In your case, solve for E.
[tex]y_{\,\mathrm{midspan}} = \frac{1}{E}\left(-0.5{\cdot}L \int_{0}^{0.5\cdot L}\frac{M(x)}{I(x)}\,dx \;\;+\;\int_{0}^{0.5\cdot L} \int_{0}^{x}\frac{M(x)}{I(x)}\,dx\ dx\right)[/tex] |
| Dec21-09, 08:51 AM | #7 |
Thanks nvn, But i can't figure out where the first integral came from.. when i worked it out my self, I only got a function of the second (double) integral. Could you explain it?
THANK YOU, THANK YOU, THANK YOU -nauen |
| Dec21-09, 11:14 AM | #8 |
Recognitions:
It is an integration constant.
| Dec21-09, 11:32 AM | #9 |
ahhhhh....it is. Thank you again nvn
| Dec22-09, 05:14 PM | #10 |
Dear nauen and nvn,
I am just reading your posts, but I am confused about what appears to be the conclusion about the deflection of a "tapered" beam being the same as the deflection of a simple beam of uniform thickness. A tapered beam(as I understand it) would be flat on the underside, and arc shaped on top, and would definately deflect less, would it not? Am I missing something? Are you guys just estimating? I am assuming the mathematics for a non-uniform beam would be trickier. Note that I have seen beam bridges that employ a thicker "web" towards the center than at the end points. I think the tapered beam problem is similar. By the way, I would also appreciate it if you guys can refer me to a book with high quality information on this topic of beams and such. Thank you. |
| Dec28-09, 08:19 AM | #11 |
| Dec25-10, 07:28 PM | #12 |
I have an identical situation posed by nauen and responded to by nvn. It is a simply supported beam with one load in the center. The beam cross section varies with x but is symmetrical across the y axis. In one situation the beam width is constant and the height varies uniformly and in another situation the beam height is constant but the width varies uniformly. In both cases the thicker/wider sections are in the middle. I am looking for the deflection at discrete values of x and not just at the midpoint. The idea is to play with the beam profile and try to approximate the deflection curve to be as close to a circular arc as possible.
I am not a mathematician so it will help if I get a solution after solving the integrals. The I(x) could be considered as (C+K*x)(h3)/12 in the case of varying width and uniform height and as (b*(C+K*x)3)/12 in the case of varying height and uniform width. C and K are constants and b is the uniform width of the beam and h is the uniform height of the beam as the case may be. If anyone can help it will be highly appreciated. |
| Dec26-10, 04:26 AM | #13 |
| Dec26-10, 05:55 AM | #14 |
Yes, I do understand that stiffer mid sections are used to withstand stress. However, in this case the "taller" and "wider" sections at the middle of the beam (both of which contribute to a higher moment of inertia) are intended to try and achieve a more circular pattern of deflection. The problem for which I am trying to get a solution inherantly requires deflection which must be circular in geometry. Stress is not a consideration. If I can get the equations given by nvn further simplified afer after performing the integration I will be able to use them to achieve the desired result through numerical means.
| Dec26-10, 08:59 AM | #15 |
Recognitions:
vsrao: In your case, change ymidspan in post 6 to y(x), for 0 ≤ x ≤ 0.5*L. And change the first and third 0.5*L to x. If you cannot solve the integrals analytically, you will need to solve it numerically.
| Dec26-10, 08:53 PM | #16 |
I understood the changes that you have referred to and I also understand that I should substitute "I" with the two different functions of X that I had included in my post # 12. My problem is that I am not a mathematician and do not know how to take this further till I get a simpler equation. I have no idea how to solve integrals numerically. If you can help more, great. Otherwise, thanks for the trouble.
| Dec27-10, 12:51 AM | #17 |
| New Reply |
| Thread Tools | |
Similar Threads for: Tapered beam deflection problem
| Deflection of tapered beam cantilever | Mechanical Engineering | 3 | ||
| Beam Deflection Problem | Mechanical Engineering | 6 | ||
| Beam deflection | General Engineering | 3 | ||
| Beam deflection | Engineering, Comp Sci, & Technology Homework | 12 | ||
