Is the existence of Hawking Radiation compatible with the Big Bang theory?
The discussion centers around the compatibility of Hawking Radiation with the Big Bang theory, exploring theoretical implications and the nature of singularities in cosmology. Participants examine the relationship between black holes and the Big Bang singularity, questioning the assumptions underlying these concepts.
  • Some participants suggest that if Hawking Radiation exists, it implies that a singularity must have evaporated before the Big Bang, leading to a contradiction between the two concepts.
  • Others argue that the singularity of a black hole is fundamentally different from the Big Bang singularity, as the former exists within space-time while the latter does not have a reference frame.
  • One participant challenges the distinction between black hole and Big Bang singularities, asserting that both should be treated consistently in theoretical discussions.
  • Another viewpoint posits that if the Big Bang singularity cannot be observed, it raises questions about its existence, paralleling the argument about personal experiences of birth.
  • A later reply emphasizes that singularities are theoretical constructs that indicate breakdowns in current models, and that cosmologists do not necessarily assume the Big Bang began with a singularity.
  • Some participants express skepticism about the implications of Hawking Radiation on established theories, suggesting that it could undermine significant aspects of 20th-century physics.
Participants express multiple competing views regarding the nature of singularities and their implications for the Big Bang and Hawking Radiation. The discussion remains unresolved, with no consensus reached on the compatibility of these concepts.
Participants highlight limitations in current theoretical frameworks, including the unresolved nature of singularities in General Relativity and the ongoing efforts to refine cosmological models. There is also mention of the potential for misinterpretation of singularities in the context of cosmology.
Ian
I had this thought today after reading about Professor Hawking's recent lecture.
If the suppsed Hawking Radiation truly exists then since all matter was supposedly concentrated into a singularity in the time before the big bang (if there was one); then this single black hole must have evaporated away according to the rules that govern Hawking Radiation.
To me this seems to say that theoretically there cannot have been both a big bang and Hawking Radiation - one does not exist, but which one?
There is a horrifying (if not hilarious) problem here: If Professor Hawking's math is correct (the guy is a brilliant with numbers) then much of 20th century theory must curl up and die!
Besides, what happens when a black hole evaporates through HR down to the mass of a proton? We have never observed proton decay, so why should a singularity of same mass as a proton decay by HR?
Astronomy news on Phys.org
A black hole singularity is different than the Big Bang singularity (an object embedded in spacetime vs. spacetime itself).
Phobos,
Why is there a difference? Matter is matter, and space-time is space-time, the interface between the two must always remain constant.
To present a difference between a black hole and the big bang singularity is a theoretical dodge.
Ian said:
Phobos,
There is no theoretical dodge. The singularity of a black hole is fundamentally different from the big bang singularity in that the singularity of a black hole exists in space-time, which gives it a reference frame, and thus can be observed in theory. The big bang singularity had no reference frame, as the concept of space-time is a result of the big bang itself, and therefore there is no observable reference frame for the big bang singularity. You can effectively view a black hole as as a vector [tex]\vec{y}[/tex] with it's endpoint at some non-zero point on a vector [tex]\vec{x}[/tex], with [tex]\vec{x}[/tex] being the big bang singularity and having it's endpoint at the origin, or zero.
If the big bang singularity had no reference frame, it simply cannot be observed in theory - i.e. it can never have happened.
You can't have it both ways!
If theory extrapolates backward to a big bang singularity of matter, it must also extrapolate backward to a 'space-time singularity' in conjunction with the matter singularity.
I cannot observe the birth of my parents. So they were never born?
If one rewinds our Galaxy,(without reference to other far away current Galaxies), then there comes a defined Horizon, wherby there is extreme particle creation. This is centered around the Blackhole that we deemed to be at our Galactic core, in a time-reversed manner.
The compaction of our Galaxy to such a phase of Virtual pair creation, has in this sense a 'perfect' background for particle creation, which is on the scale of a tear in the fabric of space, (not to be confused with a tear in spacetime) the Big-Bang is the moment of our Galaxy Creation, the singularity centered at our 'current' Milky Way, has its own separate Spacetime, far far away from other Galaxies.
If one rewinds Einstein Field Equations, then each Galaxy has separate spacetimes, only Galaxies that can be rewound and actually collide at the same instant (within the same time reversed horizon of EM Vacuum space) would share a perceived same "Big-Bang" Universal Instant.
If one Rewinds all of the actual Universe, which is supposed to be current accepted version of events, then one cannot explain how some Glaxies will not merge into the same 'singularity' at the same given instant, the moment of Universe Creation.
Just look at Andromeda, it is currently Heading towards us, if one could stop it in its tracks along with our Milkyway, then rewind both Galaxies in a Time-Reversed fashion, their proximity to each other will actually separate Exponentially, the farther back in time you rewind the Universe, the further Andromeda and the Milkyway will separate. How can their creation be at the same instant if they are moving away from each other in a time-reversal scenario?
If every single galaxy in the observable universe were actually moving away from each other, then I would conceed that any Time-reversal of the Big-Bang would infact produce a single instant of all Galaxies, and all Galaxies would share the same birthdates!
Ian this doesn't make sense and appears to be based on a misconception about what a "singularity" is, misinformation about what cosmologists assume.
You say you live in the UK. Probably you pay taxes or members of your family do. Some of that tax money goes to support research in cosmology.
If you care at all about cosmology issues, why don't you find out what's going on?
A singularity is not something in nature. It is something that occurs in a human-built theory. It's just a point or region where the theory breaks down.
The two famous kinds of singularity are failures in General Relativity (the classical 1915 GR fails at the big bang and at black holes) and there is an on-going effort to fix these failures and get rid of the singularities in GR.
Other theories can have singularities too but the famous ones nowadays are flaws in GR.
Cosmologists do not assume that the BB began with a singularity. How could they, when such a thing does not happen in nature? It is just a flaw in theory that they are in process of eliminating. The current picture is more of a changeover from contraction to expansion----a reversal----the word "bounce" has been used----it is risky to use metaphors like "bounce" or "bang" but media and the journalistic imagination seem to demand some catchy metaphor. I prefer the plainer word "reversal" for the crossover from contraction to expansion believed to have happened at the time where there used to be a singularity in the theory.
when you buy a shirt at the store it can have various kinds of defects
a seam might not have been sewn
a button may be missing etc.
singularities are flaws and there are different types
In Gen Rel the bb singularity is different kind from the bh one. Just because there is a BB singularity at the time of BB does not mean that this is the same thing as a BH! So one would not expect Hawking radiation! That is totally illogical.
You seemed to be arguing that way in your post. Like you buy the shirt and you find that a seam was not sewn and a sleeve is coming loose---so you conclude that therefore button must be missing.
It does not follow. (there might be a connection between the two types of singularity but we don't know that yet)
In any case remember that the flaws are in the theory, not nature, so we can't draw much in the way of conclusions from them until the experts fix the flaws and check the corrected theory out by observations or experiment.
  • · Replies 73 ·
