How Can a Cross Mask Transform a Circle of Light into a Square?
The discussion revolves around the transformation of a circle of light into a square using a cross mask. Participants are exploring the underlying principles of light manipulation and the feasibility of such transformations.
  • Participants are questioning the mechanics of how a cross mask can alter the shape of light, with some seeking clarification on the definition and setup of the mask. Others are considering the implications of light diffusion and the mathematical transformations involved, such as Fourier transforms.
The discussion is ongoing, with participants providing hints and asking for further elaboration on the concepts involved. There is a mix of interpretations regarding the problem, and while some guidance has been offered, no consensus has been reached.
Some participants express uncertainty about the physical feasibility of the transformation and the limitations that may arise from the geometric setup. There is also mention of specific beam profiles and mathematical functions that may play a role in the discussion.
dm9292
Question
How is a circle of light turned into a square of light using a mask with a cross. This isn't actually my homework but a challenge question.
Solution
I really have no idea I've looked around on the net and looked in the library but I can't find anything relevant. I don't actually understand how the cross manipulates the light to produce a square. I must ask is it even possible using light or do the same limitations experienced when trying to do this geometrically arise?
I couldn't really understand the problem. Could you elaborate upon it? What do you mean by a cross in a mask?
Well by a cross in a mask I mean you shine light through a square shaped image and then you have metal mask which has a thin cross in it, this is placed after the square image. By doing this the square is now turned into a circle.
dm9292 said:
Well by a cross in a mask I mean you shine light through a square shaped image and then you have metal mask which has a thin[/color] cross in it, this is placed after the square image. By doing this the square is now turned into a circle.
Whenever you have light passing through a thin aperture, diffusion should immediately come to mind.
These are the hints i got, but i am not sure where to go from there:
Say your laser has a Gaussian beam profile and you shine it through a hole to yield a Gaussian-Bessel function:
(http://www.copl.ulaval.ca/uploads/pics/Faisceaux_Bessel-Gauss_spatiotemporels_01.JPG).
How does a Fourier transform of the waveform look in 1D (ie taking an arbitrary cross-section slice of the 3D profile)?
From the transform, how do you think you create a 2D square out of it?
I'm still trying understand this and if anyone can help it would be much appreciated.
  • · Replies 22 ·
  • · Replies 31 ·
  • · Replies 16 ·
  • · Replies 33 ·
