Matter Types in Different Spatial Geometries
  • Context: LaTeX
  • Thread starter Thread starter latentcorpse
    Matter
The discussion revolves around the formatting and presentation of a LaTeX table that categorizes types of matter in different spatial geometries, specifically focusing on "Dust" and "Radiation" in various geometrical contexts. Participants seek advice on improving the table's appearance and addressing specific formatting issues.
  • One participant presents a table comparing types of matter across different spatial geometries and requests advice on improving its professional appearance.
  • Another participant suggests deleting a specific line break to resolve an incomplete line issue in the table.
  • A different participant points out an additional formatting issue with a line sticking out and asks for further advice on how to address it.
  • One participant recommends using the booktabs package instead of the standard LaTeX tabular environment, criticizing the use of vertical lines in tables.
  • Several posts diverge into unrelated topics, including matrix operations and linear equations, which do not pertain to the original table discussion.
There is no consensus on the best approach to formatting the table, as participants provide differing suggestions and some posts veer off-topic. The discussion remains unresolved regarding the optimal presentation of the table.
Participants express various formatting preferences and technical opinions, but there is no agreement on a single solution to the formatting issues presented.
latentcorpse
hi i made the following table
[itex] \begin{center}<br /> \begin{tabular}{l|l|l}<br /> \hline<br /> & \multicolumn{2}{c}{TYPE OF MATTER} \\<br /> \cline{2-3}<br /> & ``Dust'' & ``Radiation'' \\<br /> SPATIAL GEOMETRY & $P=0$ & $P=\frac{1}{3} \rho$ \\<br /> \hline \\<br /> \multirow{2}{*}{3-sphere, $K=1$} & $a=\frac{1}{2}C \left( 1 - \cos{\eta} \right) $ & $a=\sqrt{C'} \left( 1- \left( 1 - \frac{\tau}{\sqrt{C'}} \right)^2 \right)^{\frac{1}{2}}$ \\<br /> & $\tau=\frac{1}{2}C \left( \eta - \sin{\eta} \right)$ & \\<br /> \hline<br /> Flat, $k=0$ & $a= \left( \frac{9C}{4} \right)^{\frac{1}{3}} \tau^{\frac{2}{3}}$ & $a=\left( 4C' \right)^{\frac{1}{4}} \tau^{\frac{1}{2}}$ \\<br /> \hline<br /> \multirow{2}{*}{3-hyperboloid, $k=-1$} & $a=\frac{1}{2} C \left( \cosh{\eta} - 1 \right)$ & $a=\sqrt{C'} \left( \left( 1 + \frac{\tau}{\sqrt{C'}} \right)^2 -1 \right)^{\frac{1}{2}}$ \\<br /> & $\tau=\frac{1}{2}C \left( \sinh{\eta} - \eta \right)$ & \\<br /> \hline<br /> \end{tabular}<br /> \end{center}[/itex]
with the following code:
\begin{center}
\hline
\cline{2-3}
\hline \\
\hline
\hline
\hline
\end{tabular}
\end{center}
but i'd like any advice on how to make it look a bit more professional. for example, that line that's incomplete in the middle - how do i sort that?
thanks.
Delete the '\\' after the \hline after the "SPATIAL GEOMETRY" line.
cheers. i also get a line sticking out the bottom between the spatial geometry and dust columns. any advice on how to deal with that?
If you want "Spatial Geoemtry" to be in the middle vertically you can put this
\multirow{3}{*}{SPATIAL GEOMETRY}
in the first row itself.
Although n.karthick already necroposted, I guess, I can just add something as well:
Never EVER use the standard LaTeX tabular environment with vertical lines. It's absolutely horrible.
Use the booktabs package, and arrange your table layout by justifying your cells' contents.
The left side of [itex]A^*[/itex] is [itex]A = \left[<br /> \begin{smallmatrix}<br /> 9 &7\\<br /> 1 &1<br /> \end{smallmatrix} \right][/itex] and the right side of [itex]A^*[/itex] is [itex]I = \left[<br /> \begin{smallmatrix}<br /> 1 &0\\<br /> 0 &1<br /> \end{smallmatrix} \right][/itex]. The idea is to reduce the left side of [itex]A^*[/itex] from [itex]A[/itex] to [itex]I[/itex] in order to produce the right side of [itex]A^*_t[/itex] from [itex]I[/itex] to [itex]A^{-1}[/itex].
Sorry. Just testing. Apparently your testing thread is no longer active.
Now the left side of [itex]A^*_t[/itex] is [itex]I = \left[<br /> \begin{smallmatrix}<br /> 1 &0\\<br /> 0 &1<br /> \end{smallmatrix} \right][/itex] and the right side of [itex]A^*_t[/itex] is [itex]A^{-1} = \left[ \frac{1}{2}<br /> \begin{smallmatrix}<br /> 1 &-7\\<br /> -1 &9<br /> \end{smallmatrix} \right][/itex]. In other words, as [itex]A[/itex] is reduced from [itex]A[/itex] to [itex]I[/itex], [itex]A^{-1}[/itex] is simultaneously produced from [itex]I[/itex] to [itex]A^{-1}[/itex].
Now the left side of [itex]A^*_t[/itex] is [itex]I = \left[<br /> \begin{smallmatrix}<br /> 1 &0\\<br /> 0 &1<br /> \end{smallmatrix} \right][/itex] and the right side of [itex]A^*_t[/itex] is [itex]A^{-1} = \frac{1}{2} \left[<br /> \begin{smallmatrix}<br /> 1 &-7\\<br /> -1 &9<br /> \end{smallmatrix} \right][/itex]. In other words, as [itex]A[/itex] is reduced from [itex]A[/itex] to [itex]I[/itex], [itex]A^{-1}[/itex] is simultaneously produced from [itex]I[/itex] to [itex]A^{-1}[/itex].
Your problem states that [itex]325[/itex] people attended the theatre that day, grossing [itex]\$ 2675[/itex], at [itex]\$ 9[/itex] per ticket per adult and [itex]\$ 7[/itex] per ticket per child. This means that [itex]\$ 9[/itex] times the number of adults plus [itex]\$ 7[/itex] times the number of children produced [itex]\$ 2675[/itex], and that the total number of adults plus children was [itex]325[/itex]. This is your system of linear equations:
[tex] \begin{align*}<br /> 9x_1 + 7x_2 &= 2675\\<br /> \phantom{9}x_1 + \phantom{7}x_2 &= 325<br /> \end{align*}[/tex]
You mentioned that you needed to use matrices to solve the problem. Then you will need to convert your system of linear equations to matrix form, as follows:
[tex] \begin{equation*}<br /> \begin{bmatrix}<br /> 9 & 7\\<br /> 1 & 1<br /> \end{bmatrix}<br /> \begin{bmatrix}<br /> x_1\\<br /> x_2<br /> \end{bmatrix}<br /> =<br /> \begin{bmatrix}<br /> 2675\\<br /> 325<br /> \end{bmatrix} <br /> \end{equation*}[/tex]
This will produce a matrix equation of the form [itex]AX = B[/itex] for coefficient matrix [itex]A = \left[<br /> \begin{smallmatrix}<br /> 9 & 7\\<br /> 1 & 1<br /> \end{smallmatrix} \right][/itex], solution matrix [itex]X = \left[<br /> \begin{smallmatrix}<br /> x_1\\<br /> x_2<br /> \end{smallmatrix} \right][/itex], constant matrix [itex]B = \left[<br /> \begin{smallmatrix}<br /> 2675\\<br /> 325<br /> \end{smallmatrix} \right][/itex] and identity matrix [itex]I = \left[<br /> \begin{smallmatrix}<br /> 1 &0\\<br /> 0 &1<br /> \end{smallmatrix} \right][/itex] such that:
[tex] \begin{align*}<br /> AX &= B\\<br /> A^{-1}AX &= A^{-1}B\\<br /> IX &= A^{-1}B\\<br /> X &= A^{-1}B<br /> \end{align*}[/tex]
Given [itex]X[/itex] and [itex]B[/itex], you need to find [itex]A^{-1}[/itex], the inverse matrix of [itex]A[/itex], if it exists, to solve the equation. Using elementary row operations, [itex]r_i[/itex], on [itex]A^*[/itex], the augmented matrix of [itex]A[/itex], allows you to obtain [itex]A^{-1}[/itex]:
[tex] \begin{align*}<br /> A^* &= [A|I] \xrightarrow{r_1} \cdots \xrightarrow{r_n} [I|A^{-1}] = A^*_t\\<br /> &=<br /> \begin{bmatrix}<br /> 9 &7 &| &1 &0\\<br /> 1 &1 &| &0 &1<br /> \end{bmatrix}<br /> \xrightarrow{r_1} \cdots \xrightarrow{r_4}<br /> \begin{bmatrix}<br /> 1 &0 &| &\frac{1}{2} &-\frac{7}{2}\\<br /> 0 &1 &| &-\frac{1}{2} &\frac{9}{2}<br /> \end{bmatrix}<br /> = A^*_t <br /> \end{align*}[/tex]
(Refer to the Appendix for a description of the elementary row operations which transform [itex]A^*[/itex] to [itex]A^*_t[/itex].)
So that:
[tex] \begin{align*}<br /> A^{-1} &= \phantom{\dfrac{1}{2}}<br /> \begin{bmatrix}<br /> \frac{1}{2} &-\frac{7}{2}\\<br /> -\frac{1}{2} &\frac{9}{2}<br /> \end{bmatrix}\\<br /> &= \dfrac{1}{2}<br /> \begin{bmatrix}<br /> 1 &-7\\<br /> -1 &9<br /> \end{bmatrix} <br /> \end{align*}[/tex]
Since [itex]X = A^{-1} B[/itex] for [itex]X = \left[<br /> \begin{smallmatrix}<br /> x_1\\<br /> x_2<br /> \end{smallmatrix} \right][/itex], [itex]A^{-1} = \frac{1}{2} \left[<br /> \begin{smallmatrix}<br /> 1 &-7\\<br /> -1 &9<br /> \end{smallmatrix} \right][/itex] and [itex]B = \left[<br /> \begin{smallmatrix}<br /> 2675\\<br /> 325<br /> \end{smallmatrix} \right][/itex], then:
[tex] \begin{align*}<br /> \begin{bmatrix}<br /> x_1\\<br /> x_2<br /> \end{bmatrix}<br /> &= \dfrac{1}{2}<br /> \begin{bmatrix}<br /> 1 &-7\\<br /> -1 &9<br /> \end{bmatrix}<br /> \begin{bmatrix}<br /> 2675\\<br /> 325<br /> \end{bmatrix}\\<br /> &= \dfrac{1}{2}<br /> \begin{bmatrix}<br /> 2675 - 7 \cdot 325\\<br /> 9 \cdot 325 - 2675<br /> \end{bmatrix}\\<br /> &= \dfrac{1}{2}<br /> \begin{bmatrix}<br /> 2675-2275\\<br /> 2925-2675<br /> \end{bmatrix}\\<br /> &= \phantom{\frac{1}{2}}<br /> \begin{bmatrix}<br /> 200\\<br /> 125<br /> \end{bmatrix}<br /> \end{align*}[/tex]
Therefore, [itex]x_1=200[/itex] adults and [itex]x_2=125[/itex] children attended the theatre that day.
Appendix
The left side of [itex]A^*[/itex] is [itex]A = \left[<br /> \begin{smallmatrix}<br /> 9 &7\\<br /> 1 &1<br /> \end{smallmatrix} \right][/itex] and the right side of [itex]A^*[/itex] is [itex]I = \left[<br /> \begin{smallmatrix}<br /> 1 &0\\<br /> 0 &1<br /> \end{smallmatrix} \right][/itex]. The idea is to reduce the left side of [itex]A^*[/itex] from [itex]A[/itex] to [itex]I[/itex] in order to reproduce the right side of [itex]A^*_t[/itex] from [itex]I[/itex] to [itex]A^{-1}[/itex].
[tex] \begin{align*}<br /> A^* &= \; \,<br /> \begin{bmatrix}<br /> 9 &7 &|&1 &0\\<br /> 1 &1 &|&0 &1<br /> \end{bmatrix}\\<br /> &\xrightarrow{r_1}<br /> \begin{bmatrix}<br /> 1 &1 &| &0 &1\\<br /> 9 &7 &| &1 &0<br /> \end{bmatrix}\\<br /> &\xrightarrow{r_2}<br /> \begin{bmatrix}<br /> 1 &1 &| &0 &1\\<br /> 0 &-2 &| &1 &-9<br /> \end{bmatrix}\\<br /> &\xrightarrow{r_3}<br /> \begin{bmatrix}<br /> 1 &1 &| &0 &1\\<br /> 0 &1 &| &-\frac{1}{2} &\frac{9}{2}<br /> \end{bmatrix}\\<br /> &\xrightarrow{r_4}<br /> \begin{bmatrix}<br /> 1 &0 &| &\frac{1}{2} &-\frac{7}{2}\\<br /> 0 &1 &| &-\frac{1}{2} &\frac{9}{2}<br /> \end{bmatrix}\\<br /> &\; \, = A^*_t<br /> \end{align*}[/tex]
Now the left side of [itex]A^*_t[/itex] is [itex]I = \left[<br /> \begin{smallmatrix}<br /> 1 &0\\<br /> 0 &1<br /> \end{smallmatrix} \right][/itex] and the right side of [itex]A^*_t[/itex] is [itex]A^{-1} = \left[<br /> \begin{smallmatrix}<br /> 1/2 &-7/2\\<br /> -1/2 &9/2<br /> \end{smallmatrix} \right][/itex]. In other words, as [itex]A[/itex] is reduced from [itex]A[/itex] to [itex]I[/itex], [itex]A^{-1}[/itex] is simultaneously reproduced from [itex]I[/itex] to [itex]A^{-1}[/itex].
  • · Replies 0 ·
