A question in solving schrodinger's equation
  • Context: Graduate
  • Thread starter Thread starter somy
    Schrodinger's equation
The discussion revolves around the method of separation of variables in solving the Schrödinger equation, specifically addressing concerns about whether this method restricts the set of possible solutions. Participants explore the implications of assuming separable solutions and the completeness of the solution set.
  • Some participants argue that assuming a separable function restricts the solution set, potentially losing some answers.
  • Others contend that separation of variables yields all possible solutions under appropriate boundary conditions, referencing Sturm-Liouville theory and completeness of basis sets.
  • A participant suggests that the solutions obtained through separation can be combined through superposition to recover any lost solutions, asserting that the basis solutions are complete.
  • Another participant challenges the idea of superposition, claiming it does not yield new independent solutions, indicating a misunderstanding of the concept of completeness.
  • Concerns are raised about the definition of completeness and whether the basis solutions span the entire solution space of the Hamiltonian.
Participants express differing views on whether separation of variables restricts the solution set and the role of superposition in recovering solutions. There is no consensus on these points, and the discussion remains unresolved.
Participants reference mathematical concepts such as Sturm-Liouville equations and the properties of linear combinations, but there are unresolved questions regarding the completeness of the solution set and the implications of superposition.
This discussion may be of interest to students and practitioners of quantum mechanics, particularly those exploring the mathematical foundations of the Schrödinger equation and the implications of solution methods.
somy
Hi everyone;
I have a question about the separation method in solving the wave equation:
In fact when we assume the answer as a seperable function we just loose a subset of answers, because it is a RESTRICTION.
Just tell me why this assumption is correct.
Thanks a lot.
somy :smile:
If you pursue things a bit more you will find that separation does yield all possible solutions -- given appropriate boundary conditions. One approach notes that the resulting ordinary DE's are Sturm-Liouville equations which produce complete sets of solutions -- any solution can be "fourier expanded" by means of these sets. The other is more formal, and is a standard existence proof. All of this can be found in any book dealing with Partial Differential Equations. Good question.
Regards,
Reilly Atkinson
That's a good question. I wondered the same thing when I first learned it.
I'm going to shoot from the hip here and offer what I think the answer is. Someone else can correct me if I'm wrong. When we find the solutions to the Schrödinger equation, those are basis vectors. Any linear combination of those vectors is also a solution. It can be shown that the set of basis vectors is complete (that is, the linear combinations of the basis vectors exhausts the solution set of the equation).
So, I am thinking that the solutions that are "lost" in separation of variables are recovered by superposition.
Dear Tom; thanks for the answer, but what is your reason to tell that 'the superposition will cover the answers'.
another question (I know it is a bit silly!):
why the answer is complete? I mean when we say a set of answer is complete?
thanks a lot.
somy :smile:
Regards,
Reilly Atkinson
Thanks reilly;
I read your answer in griffiths' quantum book. :smile:
When you solve a PDE, you get a set of basis solutions. Your worry is that these basis solutions are not the only solutions--that we lose some solutions by imposing the separation technique. What I am pointing out is that the basis solutions (call them {φi(x,t)}) found by separation of variables are not the only solutions to the differential equation. We can take a linear combination of those basis vectors to construct more solutions, as follows:
ψ(x,t)=Σaiφi(x,t)
More below.
When I say the basis is "complete", I mean that it spans the space of the Hamiltonian. That is, any possible solution of Hψ=(i*hbar)∂ψ/∂t can be constructed from the basis vectors. So it is really as Reilly said: You don't actually lose anything with separation of variables.
Dear Tom I think you made a mistake!
In fact , by superposition you don't get any new answer, because they are not independent anymore.
Another possibility is that: I didn't get your answer!
waiting for your reply.
somy
Maybe I'm just tired, but I don't follow your statement.
As Tom said: You don't really lose anything by separation of variables.
The Schrödinger equation is linear and homogenous is [itex]\psi[/itex], so if [itex]\psi_1, \psi_2[/itex] are solutions, so is [itex]\psi_1+\psi_2[/itex].
[tex]i\hbar \frac{\partial \psi_1+\psi_2}{\partial t}=\frac{-\hbar^2}{2m}\frac{\partial^2 \psi_1+\psi_2}{\partial x^2}+V(\psi_1+\psi_2)[/tex]
(check it for yourself)
So any linear combination of solutions (obtained by separation of variables) is also a solution. Completeness said that every solution can be written as a linear combination of the solutions obtained by separation of variables.
Thanks Galileo;
I think I need to know more about completeness and its properties.
Can you help me?!
somy
Look at the standard basis for R3:
i=<1,0,0>
j=<0,1,0>
k=<0,0,1>
Let's form a vector by taking a superposition of these basis vectors:
v=axi+ayj+azk
Now, would you say that v is not different from the basis vectors simply because it is a linear combination of them? Of course not. But that is what you are saying regarding the basis {φi} and the superposition ψ=Σaiφi.
I got it!
  • · Replies 39 ·
  • · Replies 32 ·
  • · Replies 17 ·
  • · Replies 19 ·
