Port Forwarding on Router Not Supporting It
  • Thread starter Thread starter daniel_i_l
The discussion revolves around the possibility of implementing port forwarding on a router that does not support it, focusing on potential workarounds and alternative solutions. Participants explore various methods, including the use of NAT, proxy servers, and additional hardware configurations.
  • One participant questions whether it is feasible to use NAT to simulate port forwarding by sending requests from inside the LAN to the router.
  • Another participant suggests setting up a proxy server using an old computer to act as a configurable router, although they acknowledge potential performance loss.
  • A later reply reiterates the proxy server idea but highlights the complication of the modem being integrated into the router.
  • Another participant proposes that it is still possible to implement a solution with additional hardware, such as connecting a proxy PC to the router and setting up a bridge, or adding a second router to the network.
  • Concerns are raised about the simplicity of these solutions and potential issues with configuration on the existing router.
Participants do not reach a consensus on the best approach, with multiple competing views and solutions proposed. The discussion remains unresolved regarding the feasibility and effectiveness of the suggested methods.
Limitations include the lack of clarity on the router's capabilities and configurations, as well as the potential performance impacts of the proposed solutions. The discussion also depends on specific hardware setups and network configurations that may vary.
daniel_i_l
Is it possible to do port forwarding if my router doesn't support it? (I can't upgrade the firmware because it's not my router, and I can't switch routers because the router contains the modem from the ISP).
I was thinking that maybe it'd be possible to use NAT in order to simulate port forwarding. Is it possible to send certain requests to the router from inside the LAN so that it forwards signals from outside the LAN (on a specific port) back to that computer using NAT?
Or maybe it'd be possible from outside the LAN, to send a signal to the router that'd cause it to broadcast a message to the entire LAN on an obscure port. Then only one computer would be listening on that port.
Could any of these ideas work?
Are there other options?
Thanks
Computer science news on Phys.org
Not exactly sure why your router doesn't support NAT, but if it's not configurable I would opt for setting up a proxy server. You can take an old computer as the proxy. Have that machine stand between your router and your LAN. Therefore it would act as your configurable router. You will loose some performance in the network doing it that way but you would be able to have all the functionality you are looking for vs. trying to find a workaround for the router.
I'd like to do that but the modem is inside the router. The adsl line does straight into the router.
It still can be done but you'll need some more hardware. You'll have your router/modem connected to the proxy PC though one network card, you'll have to setup another network inside that same machine to bridge the connection. Then from that you would need another switch to tie all your network machines together to the proxy.
Or...
Add a second router to the network after your phone co's router. Have it grab the IP just like your computer is now and have that act as the network's gateway. That would be the simplist solution but you could run into issues if you have zero config on the phone co's router. I would borrow one before I buy just to see if you could get it to work.
  • · Replies 54 ·
9K
  • · Replies 123 ·
21K
