Can virtual particles explain quantum phenomena?
  • Context: Graduate
  • Thread starter Thread starter Tsunami
    Entanglement Vacuum
The discussion explores the concept of virtual particles and their potential role in explaining quantum phenomena, particularly focusing on the tunneling effect of electrons and entanglement. Participants examine whether these phenomena can be attributed to vacuum fluctuations rather than properties of particles or fields themselves.
  • One participant suggests that quantum phenomena, such as tunneling, could be explained by vacuum fluctuations providing an extra push to electrons, rather than by properties inherent to the particles themselves.
  • Another participant challenges this view, stating that the hypothesis lacks a quantitative model and is vague and unfalsifiable without experimental backing.
  • Some participants note that while virtual particles may be entangled, many quantum effects do not seem to rely on them, raising questions about their role as a fundamental source of quantum behavior.
  • Concerns are raised about the implications of using virtual particles in a classical manner, which may not align with experimental observations.
  • A participant expresses a willingness to return with more substantiated ideas if they can develop a reasonable system based on their hypothesis.
Participants do not reach a consensus; multiple competing views remain regarding the role of virtual particles and vacuum fluctuations in explaining quantum phenomena. The discussion reflects both support for and skepticism about the proposed interpretations.
The discussion highlights limitations in the proposed hypothesis, including its metaphysical aspects and the need for a more specific model to substantiate claims. There is an acknowledgment that many quantum effects may not be explained by virtual particles.
Tsunami
I only studied basis quantum physics as a graduate, my main focus was on light technology and I didn't carry it much further from there. But the passion for understanding how the world works remains.
Basically, I was wondering what would happen if one were to explain quantum phenomena not so much as something that is a property of particles/fields and their interactions, but of a interaction of particles/fields in a quantum-phrased version of the ether; let's call it a vacuum.
Example: the tunneling effect of electrons is not so much possible because short-time fluctuations in energy are possible and present in the electrons, but because vacuum fluctuations give the electron or electrons an extra shove, allowign them to tunnel.
At first glance, this explanation seems equivalent to the original one, similar to Lorentz' ether explanation in pre-relativity times.
The other example that could be investigated is entanglement. If entanglement becomes a property of the vacuum fluctuations (something that is always there, everywhere), that seems as sensible enough to consider as an explanation...
Basically, what I'm hoping for as a response is an experiment that shows why this interpretation will come into problems. If it doesn't, at least I know that I'm making a merely metaphysical suggestion here, and I should consider it as such.
Awaiting your response,
Tsu
You need to come out with the model that produce a quantitative description of the tunneling current based on your hypothesis. What you've described is vague and, really, unfalsifiable. You need to show how, with changing barrier potential and width, that you can get the same experimental result. Till then, there's nothing to show if you're right or wrong.
Zz.
Tsu
As ZapperZ says (and you suggest too), there is a metaphysical aspect to your hypothesis. We would imagine that virtual particle pairs are entangled (as spin must add to zero), so I can see how you might arrive at your hypothesis. I believe I have even seen a paper that loosely maps to your idea (although not what I would call generally accepted - it is purely theoretical).
But even virtual particles exhibit quantum effects, and many quantum effects have apparently nothing to do with virtual particles. So it seems a stretch to speculate that they are the source themselves. For example, how to explain quantum non-locality? Or the Heisenberg Uncertainty Principle? You end up trying to use the virtual particles in a classical fashion, and that just doesn't fit with experiment.
So I can't think of any experiment that supports your idea, but you would need to be more specific to get a citation to one that rules it out.
Ok, that makes sense. It does give me the impression that even as a metaphysical concept, the idea could get into problems when tracing out the consequences.
If I manage to substantiate a reasonable system, I'll return to this thread, but if not you can expect this thread to die a slow death.
Thanks though for considering the thought.
  • · Replies 58 ·
  • · Replies 41 ·
