suffian
Having some trouble understanding why the conclusion I am arriving at is not true. It has to do with showing that it is easier to balance a pool stick with finger on the tapered end.
Summary of the problem:
Rod of mass M with clay of mass M attached to one end. The clay represents the thick end of pool stick. Find the angular acceleration of the system if the rod is placed vertical on a frictionless tabletop and tipped a small angle theta (for both clay touching and not touching surface). The conclusion should be that the angular acceleration is smaller when the clay is not in contact with the surface.
My analysis:
Take as a frame of reference the center-of-mass of the system and assume that the axis of rotation in this frame is fixed. The external torque is equal to the inertia times ang acceleration. From this it should become mostly algebraic.
[tex]\alpha_\text{thick} = \frac{\tau}{I} = \frac{N \sin \theta \cdot L/4}{10/48 ML^2} = \frac{6}{5} \frac{N \sin \theta}{M L}[/tex]
[tex]\alpha_\text{taper} = \frac{\tau}{I} = \frac{N \sin \theta \cdot 3L/4}{10/48 ML^2} = \frac{18}{5} \frac{N \sin \theta}{M L}[/tex]
From this it appears that the angular acceleration with the tapered end down is greater, which means it would be harder to balance.
edit: i see now that the book did its calculations with the axis of rotation passing through where the rod touches the surface. but i don't understand how this could be correct because that axis moves while not passing thru the center-of-mass. therefore i don't see how torque = inertia x ang. acc.
My analysis:
