What is the pdf of resistor values (tolerances)
  • Thread starter Thread starter Rib5
    Pdf Resistor
The discussion revolves around the probability distribution function (pdf) of resistor values, particularly focusing on the implications of resistor tolerances and how they relate to statistical distributions. Participants explore the nature of these distributions, including potential Gaussian characteristics, and the impact of manufacturing processes on resistor values.
  • Some participants propose that resistor values might follow a Gaussian distribution, questioning whether the ±5% tolerance implies a certain percentage of resistors fall within those bounds.
  • Others clarify that the ±5% tolerance guarantees that all resistors are within that range, but this does not ensure that specific circuit requirements will be met.
  • A participant expresses skepticism about the reliability of tolerances, suggesting that it is hard to believe that no resistors would fall outside specified tolerances.
  • There is a discussion about the implications of testing and sorting resistors, with some suggesting that higher precision resistors are weeded out from lower tolerance groups.
  • Some participants speculate that the distribution of resistor values could be a truncated Gaussian or exhibit binomial characteristics due to manufacturing processes.
  • Concerns are raised about the cost of 100% testing in manufacturing and the potential for manufacturers to rely on sampling instead.
  • Participants discuss the use of Monte Carlo simulations and the need for sufficient runs to account for variations in tolerances without necessarily defining a specific distribution shape.
Participants express differing views on the nature of resistor value distributions and the implications of tolerances. There is no consensus on whether a Gaussian distribution accurately represents resistor values, and the discussion remains unresolved regarding the specifics of how tolerances relate to actual resistor performance.
Participants mention the potential for non-normal distributions when combining resistor values in applications like voltage dividers, indicating that the shape of the distribution may not be straightforward due to manufacturing processes.
This discussion may be of interest to those involved in electronics design, manufacturing, or quality assurance, particularly in understanding the statistical behavior of component tolerances and their implications for circuit performance.
Rib5
Hi guys,
I was reading about monte carlo analysis in the introduction from a textbook, and they gave an example of a voltage divider. They assumed resistor values had an equal probability of having values between the two tolerances. I know this is a simplistic assumption and I was wondering what kind of distribution resistors really follow.
I am guessing that it is most likely a gaussian distribution, but just wanted to know if that is specified somewhere. What does +-5% really mean? Is it that 90% of the resistors will be within those bounds? or does it have to do with standard deviation?
It is a guarantee that ALL resistors are within 5% of of spec'd value. For example, a 100 ohm resistor with a tolerance spec of +-5% could be anywhere between 95 and 105 ohms. It is NOT a guarantee that a circuit will work that calls for a 97 ohm resistor when replacing it with a 100 ohm +-5% resistor.
I find it hard to believe that no matter how many resistors you bought that you would NEVER get a value outside of the tolerances?
Two sigma is 95% and that's what I take it to mean. The pdf might not be bell-shaped because some resistors were removed and labelled 2%.
There are rules for finding tolerances for uncorrelated errors. If I lay my hands on it I'll post it. It saves you from doing a monte carlo.
whome9 said:
... because some resistors were removed and labelled 2%.
Yep. The good ones (1%) are weeded out first then the 2%, etc. So with the 5%, 100ohm resistors you will probably not find one that is exactly 100ohm.
The only thing I don't like about this is that the higher precision resistors are supposed to be more stable, yet they come from the same batch. Their initial values may be close, but they won't hold over time.
So what do you think is acceptable? One resistor out of every 1000 is 5.1% off? One out of every 10,000 is 7% off? One out of every 1,000,000,000 is 40% off? Where do you draw the line?
At the 2 sigma level with a bell-shaped curve you would get an outside value 1 time out of 20. 3 sigma, 1 time in 100.
I'm don't care what the tolerance is. My question was about the distribution of values around those tolerances, this way you can predict what values you might get.
That's what 100% testing gets you. Resistors are 100% tested before being packaged for shipment. That's true for most types of components.
I'm guessing it would be a truncated Gaussian (because of the 100% manufacturing test that I just mentioned). However, it could have some binomial character to it, if the resistor type lends itself to sorting at test. The only way to be sure would be to contact the manufacturer and see if they would/could tell you.
BTW, even for Monte Carlo purposes, you don't generally need to include a distribution attribute for the variation of values. As long as all components are varied across their tolerance, and as long as you get in enough runs to cover all the combinations of tolerances, you should be able to bracket the operation of the circuit.
Even in a corporatocracy like the US?
100% testing is costly, and with sampling the manuf. can play the odds. Almost no one will sue over an out-of-tolerance resistor.
Ah ok, thanks guys. I didn't realize that they actually tested all the components! This makes a lot more sense to me now.
Yep. If the datasheet lists the tolerance, it is tested in manufacturing. The tempco is not 100% tested, obviously, and would generally be given as a typical value. Generally if the datasheet lists a min or a max for a simple component (or tolerance), it will be tested. Sometimes the datasheet will explicitly say that some value is not 100% tested, but that is the exception.
For a voltage divider you could use formulas for uncorrelated errors. If I can find my hard copy I'll post them.
Another way is to approximate the normal distribution with 6, 10 or 20 points and then have your spreadsheet combine them according to the voltage divider formula.
20 points gives you 400 combinations, but some repeat.
You may not need the shape of the distribution but you can find the 5% endpoints.
Multiplying and dividing normal distributions gives you non-normal distributions.
  • · Replies 60 ·
9K
