Space-time symmetry (Langrangian Mechanics)
The discussion focuses on deriving the conserved quantity in the context of space-time symmetry using Lagrangian mechanics. The key transformation involves the Taylor expansion of the Lagrangian, L, and the function q(t) with respect to the parameter ε. The participants clarify that the term O(ε²) arises from the Taylor expansion, and the correct expression should include a factor of ε in the integral. The final formulation confirms that the relationship between the integrals holds true when properly expanded.
  • Understanding of Lagrangian mechanics and the role of the Lagrangian function, L.
  • Familiarity with Taylor series expansions and their applications in physics.
  • Knowledge of calculus, particularly differentiation and integration techniques.
  • Concept of conserved quantities in the context of symmetries in physics.
  • Study the derivation of Noether's theorem and its implications for conserved quantities.
  • Learn advanced techniques in Taylor series expansions and their applications in physics problems.
  • Explore the relationship between symmetries and conservation laws in classical mechanics.
  • Investigate the applications of Lagrangian mechanics in modern physics, including field theory.
Students and professionals in physics, particularly those specializing in classical mechanics, theoretical physics, and mathematical physics. This discussion is beneficial for anyone looking to deepen their understanding of space-time symmetries and Lagrangian formulations.
vertices
When deriving the conserved quantity in the case of space-time symmetry, a line in my notes goes from:
[tex]\int{dt.(1+\epsilon\dot{\xi}).L[q(t+\epsilon\xi)+{\delta}q(t+\epsilon\xi)]} - \int{dt.L[q(t)+{\delta}q(t)]}[/tex]
where L is the Lagrangian and [tex]\xi[/tex] is a function of time and both integrals are over the same time interval, to:
[tex]\int{\dot{\xi}L+\xi\frac{dL}{dt}+O(\epsilon^{2})}[/tex]
I can't see how these two lines equal one another.
How does the [tex]O(\epsilon^{2})[/tex] come about?
Thanks.
That would be the result of a Taylor expansion in [itex]\epsilon[/itex]. Also I think you're missing a factor in the last expression, and that it should be
[tex]\int \mathrm{d}t\,\epsilon\biggl(\dot{\xi}L + \xi\frac{\mathrm{d}L}{\mathrm{d}t}\biggr) + O(\epsilon^2)[/tex]
thanks diazona, much appreciated:
I tried Taylor expansion as you suggested (and I did get the right answer) but I am not sure whether I have done so mathematically correctly or not. Can you check whether or not I am on the right lines...
We have [tex]\int{dt.(1+\epsilon\dot{\xi(t)}).L[q(t+\epsilon\xi(t))+{\delta}q(t+\epsilon\xi(t))]} - \int{dt.L[q(t)+{\delta}q(t)]}[/tex]
start with [tex]L[q(t+\epsilon\xi(t))][/tex]
if we first Taylor expand the bit in parenthesis (ie. [tex]q(t+\epsilon\xi(t))[/tex]) we get
[tex]q(t+\epsilon\xi(t))=q(t)+\frac{{\partial}q(t)}{{\partial}t}\epsilon\xi(t)+...[/tex]
therefore[tex]L[q(t+\epsilon\xi(t))=L[q(t)+\frac{{\partial}q(t)}{{\partial}t}\epsilon\xi(t)+...][/tex]
This is equal to:
[tex]L(q)+\frac{{\partial}L}{{\partial}q}\frac{{\partial}q(t)}{{\partial}t}\epsilon\xi(t)+...[/tex]
but
[tex]\frac{{\partial}L}{{\partial}q}\frac{{\partial}q(t)}{{\partial}t} = \frac{{\partial}L}{{\partial}t}[/tex] (CANCELLING the 'dq's)
So:
[tex]L[q(t+\epsilon\xi(t))]=L(q)+\frac{{\partial}L}{{\partial}t}\epsilon\xi(t)+smaller terms][/tex]
Thanks.
