Material Selection, Insulator, Cryo Temp
The discussion revolves around selecting an insulating material for a washer or disk to insulate stainless steel at cryogenic temperatures, specifically around 50 Kelvin. Participants explore various materials suitable for low thermal conductivity and durability under compressive loads in cryogenic conditions.
  • One participant inquires about materials with low thermal conductivity and durability for use at 50 K, emphasizing performance over cost.
  • PTFE is suggested as a good option for temperatures around 77 K.
  • Another participant raises the possibility of polycarbonates, questioning their performance at cryogenic temperatures.
  • Micarta and cryogenic G10 are recommended as commonly used materials for inner vessel supports in cryogenic tanks, noted for their low thermal conductivity.
  • Wool is proposed as an unconventional insulating material, with anecdotal evidence of its effectiveness at very low temperatures.
  • PTFE is ultimately chosen by one participant, with PCTFE (NeoFlon) selected for critical sealing areas due to its performance at even lower temperatures.
  • Discussion includes a comparison of Neoflon and PTFE, highlighting Neoflon's structural advantages and the importance of considering both thermal conductivity and material strength for structural supports.
Participants express multiple competing views on suitable materials, with no consensus reached on a single best option. Various materials are discussed, each with their own merits and limitations.
Participants note that the effectiveness of materials may depend on specific application requirements, including load conditions and temperature ranges. There is also mention of the need to balance thermal conductivity with structural integrity.
Individuals involved in cryogenic engineering, materials science, or those seeking solutions for low-temperature applications may find this discussion relevant.
dfly9891
Hi,
I've got an applications where I need an insulating washer/disk in order to insulate stainless from stainless at 50 degrees Kelvin. I need help in selecting a material to do the job. I.e. low thermal conductivity, durable enough at 50 K to take a compressive static load of approx 40 lbf. Performance, rather than cost, is is the most important characteristic in this case. Any Ideas??
Parameters: OD of washer ~2" Thickness ~1/4"(I can vary on the thickness if necessary but not on the OD). OD of footprint of 40lb load (compression spring) ~1.5".
Thanks in Advance.
PTFE is pretty good at 77k
Thanks. Someone on the engineering forum said the same thing. What about polycarbonates though? They can have lower thermal conductivities but I'm not sure of their performance at cryo temps. Thoughts?
Micarta is commonly used for inner vessel supports on cryogenic tanks. Also, crygenic G10 is another excellent choice. Both have relatively low thermal conductivity.
Take a look for properties here:
http://cryogenics.nist.gov/MPropsMAY/material%20properties.htm
Thanks Q_Goest. This helps a lot. I'll look up the properties and costs. Will let you know...
Thanks. I'm going with PTFE.
Uh, have you considered wool? Pretty cheap, and if I'm not mistaken, it http://en.wikipedia.org/wiki/Wool_insulation" .
I've used simple sheepskin for apps involving temps to below -100 deg F. Get's a bit crisp, but it still works well!
Wool? Nice. Now that's thinking outside the box. I like people like you.
I'm going to be putting the insulator in -370 F conditions so I'm sticking with PTFE for now. There is a seal area with critical dimensions so I'm using PCTFE (NeoFlon) for that as PCTFE is good to -400F while PTFE is good to about -325F
Hi dfly. Neoflon and PTFE are commonly used for applications down to -452F. Valve seats used in LHe service for example, are commonly made from Neoflon.
Of the two, Neoflon is your better structural material due to the crosslinking. As I'd mentioned at Eng-tips, Teflon needs to be reinforced when used as a structural material.
Note also that simply finding the lowest thermal conductivity isn't necessarily going to give you the best material for structural supports. Teflon has a much lower strength than Neoflon, so the Neoflon support can be made with a smaller cross section. Similarly, Micarta and G10 have an even higher strength, so supports made from that material can be made with an even smaller cross section.
The best material takes into consideration what can be done by minimizing not just the thermal conductivity of the material, but limiting the cross sectional area to minimize the overall heat transfer.
  • · Replies 0 ·
14K
