| Thread Closed |
solid and hollow shafts |
Share Thread | Thread Tools |
| Dec26-09, 02:13 PM | #1 |
assuming that the maximum shear stress and torsion are the same in both shafts design a hollow shaft to replace the solid one . the ratio diameters is to be 0.6 for the maximum shear stress i calculated 79.95 x 10 ^6 mn/m2 and for the torsion i calculated 122.78x10^3 in the previous question. 2. Relevant equations (T) torque/ (J) polar second moment of area and (t) shear stress/ ( r) radius polar second moment of area = pie (d4-d4)/32 radius = D/2 3. The attempt at a solution (j)= pie ((0.6)4-d4)/32 = 0.08545 d4 (r) = 0.6/2 = 0.3 solid shaft = j/r = 152.41x10^6 / 99.25 x 10 ^-3 = 1.535 x 10^-3values from previous question hollow shaft = j/r = 0.08545/0.3 = 284.83 x 10^ -3 d 3 square root with 1.535 x 10^-3/284.83 x 10^-3 under it = 175.32 x 10^-3 D= 0.6 x D = 0.6 x 175.32 x 10^-3 = 105.19 x 10^-3 therefore the dimensions are 175mm and 105mm i think these values are wrong as the solid shaft is 198.5mm and i always thought the hollow shaft would be larger in diameter please help as i dont no what i have done wrong.. |
| Dec27-09, 09:06 AM | #2 |
| Dec27-09, 10:43 AM | #3 |
Had another look today and relised where i have went wrong here is my new answers :
torsion / polar second moment of area = tau/ radius : (t) 122.78 x 10^3/(j) 0.08545 = (tau) 79.95 x 10 ^6/d/2 : (t) 122.78 x 10 ^3/(tau) 79.95 x 10 ^6 = (j) 0.08545 / d/2 D= 3 square root with 122.78 x 10^3/79.95 x 10 ^6 divide by 2 x 0.08545 = 207.90x10 ^-3m d= 0.6 x D = 0.6 x 207.90 x 10 ^-3 = 124.74 x 10 -3m the dimensions for the hollow shaft are D=208mm and d=125mm hopefully i am correct this time!!!!! |
| Dec27-09, 12:15 PM | #4 |
Yes, that looks about right.
| Dec27-09, 12:54 PM | #5 |
thanks for checking
| Thread Closed |
| Thread Tools | |
Similar Threads for: solid and hollow shafts
| Hollow Pipe vs Solid Rod | Classical Physics | 8 | ||
| Tubes: Hollow vs Solid | Mechanical Engineering | 26 | ||
| hollow vs. solid shafts | Mechanical Engineering | 8 | ||
| A different take on the hollow vs solid rod | Classical Physics | 11 | ||
| Potentials of Hollow and Solid Spheres | Introductory Physics Homework | 1 | ||
