Compute the area under the curve
  • Thread starter Thread starter (@apache@)
    Area Curve
The discussion revolves around computing the area under a curve defined by the equation (x^3+y^3)^2=x^2+y^2, with an emphasis on the constraints x>0 and y>0. The problem involves transforming the equation into polar coordinates and evaluating the corresponding integral.
  • Participants discuss transforming the equation into polar coordinates and the challenges associated with integrating the resulting expression. There is also a question raised about the clarity of the region described by the "area under the curve."
Some participants have provided guidance on the integral setup and noted discrepancies in the results obtained. There is an acknowledgment of a potential factor that may have been overlooked in the calculations, but no consensus on the final result has been reached.
Participants are working under the condition that x and y are both greater than zero, which influences the limits of integration and the interpretation of the area being computed.
(@apache@)
Hi everyone,
can you give me some hint to solve this? please
Compute the area under the curve:
[tex](x^3+y^3)^2=x^2+y^2[/tex]
I've been trying to transform it into polar coordinates, but I've finished when I get the equation for the radius:
[tex]r^2=1/((\cos(\theta))^3+(\sin(\theta))^3)[/tex],
because then I get the integral which should not be easily integrated (of course I've compute with Jacobian)
thanks for yout attention
Have you looked at the graph? It isn't even clear what region the "area under the curve" describes.
I am sorry, I forgot add this condition: [tex]x>0, y>0[/tex], so then I will get the integral in this case:
[tex] \int\limits_{0}^{\pi/2}(\int\limits_{0}^{\frac{1}{\sqrt{\cos^3\alpha+\sin^3\alpha}}}r\,dr)\,d\alpha[/tex],
which results to [tex]1/3 (\pi+2 \sqrt{2} \tanh^{-1}(1/\sqrt{2}))[/tex], but it's little bit different form the correct result which is [tex]\frac{\pi}{6}+\frac{\sqrt{2}}{3}\ln(1+\sqrt{2})[/tex]
Your integral looks OK but your answer is off by a factor of 1/2. You probably dropped it somewhere in the calculation.
Yes, you're right. l forget 1/2 in front of integral, then the results are same:
1.8781645380502384306795745680939249649333168829204582775232678988974988081580885734995703727615411934.
Thanks for your time.
  • · Replies 20 ·
