Thread Closed
Laser: CW-oscillation in a 3-level laser
Share Thread
Dec28-09, 10:20 AM   #1
Hi
At continuous-wave oscillation the gain is equal to the threshold gain, i.e. g = gthreshold. Now in my book, I have the following expression for the steady-state population-inversion for a three-level laser
N2, steady state - N1, steady state = (P-Γ12)/(P+Γ12)NT
where NT=N1, steady state+N2, steady state, P is the pump rate and Γ12 is the rate at which level 2 decays into level 1. Now my question is: If at CW-oscillation g=gt, then why is it that we can change N2, steady state - N1, steady state (and thereby the gain) in a three-level laser at steady-state? Isn't this a contradiction?
PhysOrg.com physics news on PhysOrg.com
>> Surprising turns in magnetic thin films could lead to better data storage
>> Novel synthesis technique for high efficiency conversion of source gas to diamond
>> Scientists capture crystallization of materials in nanoseconds
Dec28-09, 12:41 PM   #2
Recognitions:
What happens if you increase the pumping power further after laser oscillation sets in, is called gain clamping or upper population clamping. Any atoms you pump into the upper level will be almost immediately converted into laser light as fast as you pump them up (well - on statistical average, of course not necessarily the same atoms you just pumped up). Therefore the decay rate will also momentarily increase. If you do not increase the pump power constantly but just add short pulses of high pump power, you might also see the population numbers and the intracavity photon number undergo relaxation oscillations according to the fluctuation-dissipation theorem.
Thread Closed
Similar discussions for: Laser: CW-oscillation in a 3-level laser
Thread Forum Replies
intensity of red laser vs blue laser Advanced Physics Homework 4
Would it be possible to produce a dif laser by 382nm UV diode laser with a 910nm IR Classical Physics 3
Diffusion of laser light for measuring laser power General Physics 3
Double slit problem, finding λ of second laser given data about first laser... Introductory Physics Homework 2
