Physical interpretation of unitary transformation
The discussion revolves around the physical interpretation of unitary transformations, particularly focusing on the implications of transposing matrices and taking their conjugates within quantum mechanics. Participants explore the nature of these transformations in relation to information preservation, symmetry, and the representation of operators.
  • Some participants suggest that unitary transformations are "information preserving," as indicated by their relationship with von Neumann entropy, where initial and final states are equally probable.
  • There is a discussion on how physical expectation values remain invariant during unitary transformations, which may relate to information processes in quantum mechanics.
  • One participant notes that the action or Hamiltonian invariant under transformations corresponds to the symmetry of the system, mentioning both continuous and discrete transformations.
  • Another participant elaborates on the mathematical structure of unitary transformations, explaining how they can be viewed as projections and how they relate to the eigenvalues and eigenvectors of operators.
  • There is a suggestion that non-information preserving transformations might be considered more "interesting" than unitary transformations.
Participants express various viewpoints on the implications and interpretations of unitary transformations, with no consensus reached on a singular interpretation. The discussion includes both supportive and critical perspectives on the nature of these transformations.
Some claims depend on specific definitions of "physical" traits and may involve assumptions about the nature of information in quantum mechanics. The discussion includes unresolved mathematical steps and varying interpretations of symmetry and invariance.
hasanhabibul
what actually happens physically ...when we make transpose of a matrix...and in unitary transformation we transpose the matrix and take the conjugate...physically what type of change happens in it.
I guess the answer depends what trait you take as "physical" traits, here's some spontaneous thoughts.
One important thing is that in terms of the normal QM entropy of von-neumann, unitary transformations are for example "information preserving". When we consider unitary time evolution, the initial and final states are somehow equally a priori probable if that's measured in terms of von-neumann entropy.
Also, generally physical expectation values are invariant during unitary transformations.
This is interesting in the context of information processes where in general one can loose, gain or maintain information. So unitary processes in QM, IMHO describe a special case of information processes, where the state of information changes, but in a way that maintain total entropy. One could even think of all states generated by unitary transformations as defining a sort of equiprobable class of states.
So non-information preserving transformations are IMO more "interesting".
/Fredrik
the action S or hamiltonian invariant under transformations corresponds to the symmetry of the system. these transformations may be continuous( U(1), SU(2)) or discrete.
while the state may not retain these symmetry--symmetry breaking.
Well, consider what happens under a unitary transformation when dealing with finite matrices. Say you have unitary matrix U, and you are transforming matrix H. U^-1 HU is the unitary transformation. Recall a unitary matrix is composed of orthonormal columns. This means its adjoint is its inverse (assuming a square matrix). So, HU gives the matrix H acting on each column of U. So if we call the columns |a_n>, then since they are also the eigenvectors of U, U=|u_n><u_n| as n runs through all the columns (this summation will be implied from now on). Notice U is just a projection operator. And U^-1=|u_n*><u_n*| where * denotes the complex conjugate. Now, let's represent H with its eigenvectors |H_k>, and eigenvalues E_k: H=|H_k>E_k<H_k|. So, you can see that U^-1HU is simply equal to |P_k*>E_k<P_k| where |P_k> denotes the projection of |H_k> onto U space. U^-1HU is clearly (and by definition) isomorphic to H. So in conclusion, what you are doing is representing H in terms of the space represented by U.
Recall that if H commutes with U U^-1 HU=H (proved by multiplying both sides by U), H is invariant. That's where the symmetry stuff comes from. Go ahead an play around with the this (like sharing eigenstuff when H and U commute-stuff like that). You should right away see the mathematical origins of much of the quantum physics theorems.
Good question! It has lots of interesting answers!
  • · Replies 20 ·
  • · Replies 47 ·
  • · Replies 47 ·
  • · Replies 68 ·
