Work Done by Increasing Plate Distance of Flat Capacitor
The discussion focuses on calculating the work done when the distance between the plates of a flat capacitor is doubled. The initial capacitance (C(A)) is calculated as 4.43 x 10^-12 F, and the final capacitance (C(B)) after increasing the distance to 4 cm is 2.21 x 10^-12 F. The charge remains constant at 4.43 x 10^-10 C, leading to a final voltage (V(B)) of 200 V. The work done (W) is determined to be 2.21 x 10^-8 J, confirming the calculations as correct.
  • Understanding of capacitor fundamentals, including capacitance and charge.
  • Familiarity with the equations for capacitance (C= ε*A/d) and energy (E= ½ Q*V).
  • Knowledge of electrical energy concepts and work-energy principles.
  • Basic proficiency in unit conversions, particularly between centimeters and meters.
  • Study the effects of plate area on capacitance in flat capacitors.
  • Learn about energy storage in capacitors and its applications in circuits.
  • Explore the relationship between voltage, charge, and capacitance in different configurations.
  • Investigate the impact of dielectric materials on capacitance and energy storage.
Students studying electrical engineering, physics enthusiasts, and anyone interested in understanding capacitor behavior and energy calculations in electrical circuits.
mmoadi
Flat capacitor with a plates distanced d = 2 cm and the area A= 1 dm² are connected to a voltage U = 100 V. We disconnect the source of voltage and we increase the distance between the plates to twice the distance. How much work is done?
C= ε*A/ d
Q= C*V
E= ½ Q*V
W= ΔE
Calculating the capacitance at point A:
d(A)= 0.02 m, A= 0.01 m², ε= 8.85 × 10^-12 As/Vm
C(A)= ε*A/ d(A)
C(A)= [(8.85 x 10^-12 As/Vm)*(1 x 10^-2 m^2)]/ (2 x 10^-2 m)
C(A)= 4.43 x 10^-12 F
Calculating the capacitance at point B:
d(B)= 0.04 m, A= 0.01 m², ε= 8.85 × 10^-12 As/Vm
C(B)= ε*A/ d(B)
C(B)= [(8.85 x 10^-12 As/Vm)*(1 x 10^-2 m^2)]/ (4 x 10^-2 m)
C(B)= 2.21 x 10^-12 F
Calculating the charge on the plates:
Q= C(A)*V(A)
Q= (4.43 x10^-12)*100 V
Q= 4.43 x 10^-10 C
We know that the charge should be the same on both plate A and plate B so we use that piece of information to calculate the voltage of plate B:
V(B)= Q/ C(B)
V(B)= (4.43 x 10^-10 C)/ (2.21 x 10^-12 F)
V(B)= 200 V
Calculating the electrical energy in plate A:
E(A)= ½ Q*V(A)
E(A)= ½ (4.43 x10^10 C)* 100 V
E(A)= 2.22 x10^-8 J
Calculating the electrical energy in plate B:
E(B)= ½ Q*V(B)
E(B)= ½ (4.43 x10^10 C)* 200 V
E(B)= 4.43 x10^-8 J
Calculating the work:
W= ΔE
ΔE= E(B) – E(A)
ΔE= 4.43 x10^-8 J - 2.22 x10^-8 J
ΔE= 2.21 x 10^-8 J
Are my calculations correct?:confused:
Thank you for helping!:smile:
Your calculations are correct. The distance of the plates compared to their size is too large
to make the capacitance calculation so accurate however.
:smile:Well, at least I cracked one problem!:biggrin:
Thank you for your help and HAPPY NEW YEAR:wink:!
  • · Replies 16 ·
