Wave on a string tied to a weight
The discussion centers on calculating the time it takes for a wave to travel along a 17 m string with a total weight of 13 kg tied to a ceiling and a 13 kg weight at the lower end. The relevant equation for wave speed is given as v = (T/μ)^(1/2), where T is the tension and μ is the linear mass density. Participants clarify that the tension T at a point y is equal to the weight of the mass below that point, leading to the expression V(y) = (T/μ)^(1/2). The solution requires rearranging and integrating to determine the total time for the wave to traverse the string.
  • Understanding of wave mechanics and wave speed equations
  • Familiarity with tension and linear mass density concepts
  • Basic calculus for integration and rearranging equations
  • Knowledge of gravitational acceleration (g = 10 m/s²)
  • Study the derivation of wave speed in strings using the formula v = (T/μ)^(1/2)
  • Learn how to calculate tension in a string with varying mass distribution
  • Explore integration techniques for solving differential equations in physics
  • Investigate the effects of different weights and string lengths on wave propagation
Physics students, educators, and anyone interested in understanding wave dynamics in strings and their applications in mechanical systems.
Issacros
A 17 m string of weight 13kg is tied to the ceiling at its upper end, and the lower is tied to a weight of 13 kg. how long will it take a wave to get from one end to the next? (g=10 m/s^2)
v = (T/u)^(1/2)
well, i think mass(y)=(13+13y/17)kg
therefor T=ma= (13+13y/17)kg*19m/(s^2)
V(y)=(T/u)^(1/2)=>> (10y)^1/2
beyond this point I'm stuck. Thanks in advance.
OK, this is the total mass for all points below y (measured from the bottom of the string).
Where did you get 19 m/s^2? The tension at point y is equal to the weight of the mass below that point.
Not sure where this last expression came from. Use the correct expression for T(y).
Hint:
V(y) = (T/μ)^(1/2)
dy/dt = (T/μ)^(1/2)
Rearrange and integrate to find the total time.
