Relativity: Is Faster Light Travel Possible?
  • Context: Graduate
  • Thread starter Thread starter Jim Beam
    Light
The discussion revolves around the possibility of faster-than-light travel in the context of relativity, specifically examining the behavior of photons moving toward each other. Participants explore the implications of relativistic velocity addition and the concept of a "rest frame" for photons.
  • One participant suggests that if two photons approach each other, one could claim to be stationary and view the other as moving at twice the speed of light, raising questions about the nature of light speed.
  • Another participant explains that the relative speed of two objects moving at relativistic speeds cannot be determined by simple addition, referencing the relativistic velocity addition formula.
  • A third participant concurs, stating that each light ray would perceive the other approaching at the speed of light.
  • A participant acknowledges understanding that light rays see each other moving at the speed of light but expresses uncertainty about the reasoning behind it.
  • Another participant reiterates the initial claim about stationary frames but emphasizes that a photon cannot claim a stationary existence, explaining the complexities of defining a "rest frame" for a photon and the implications of infinite contraction and dilation in such a frame.
Participants generally agree on the application of the relativistic velocity addition formula but disagree on the implications of a photon having a rest frame or measuring speed relative to another photon. The discussion remains unresolved regarding the physical meaning of such measurements.
There are limitations regarding the assumptions made about the existence of a rest frame for photons and the implications of relativistic effects on their perception of speed. The discussion highlights the complexities and unresolved nature of these concepts within the framework of special relativity.
Jim Beam
according to relativity, two objects moving toward each other through space in un-acclerated motion have equal right to declare themselves stationary and viewing the other as moving. if two photons are approaching each other at the speed of light, is it not correct for one of the photons to claim its stationary existence while viewing the other approaching at twice the speed of light? If that's a correct assumption, then technically, faster the light travel would a reality. I know I've probably got something wrong, which is why i am asking you all if its a possibility.
When two things are going very fast (relative to a stationary observer), the speed relative to each other is not gotten by simple addition. The general formula is:
u=(v+w)/(1+v*w/c2), where v and w are the individual speeds and u is the relative speed between the two things. Note that for v=w=c, then u=c.
What mathman said!
In other words, either light ray would "see" the other approaching AT the speed of light.
i knew the light rays would see each other moving at the speed of light, but what i didn't know was why. thanks for the help guys.
Perfectly true.
If you naively plug in u=v=c in the relativistic velocity addition formula, you find the relative speed to be c. However, I would not put too much trust in this result. The reason for that is that a photon cannot claim its own stationary existence. (There has been some discussion here about this issue, do a PF search for a universe containing a single photon.) The "rest frame of a photon" is extremely ill defined from the vantage point of relativity, and no meaningful physics can be done using it. If we try to define it by Lorenz boosting to the photon frame, we find that space is infinitely contracted and time is infinitely dilated. Hence a photon is not aware of its own existence, or the existence of the rest of the universe. It experiences no awareness of either time or space from the moment it is created to the moment it is destroyed (here 'moment' is defined by some inertial massive observer), nor is it aware of the other photon. Hence I don't think that it is physically meaningful within SR to ask what speed does a photon "measure" for another photon - it cannot measure to begin with. But I might be wrong, and in any case if the question of the speed of one photon relative to the answer has a physically meaningful answer, it must be c.
  • · Replies 24 ·
  • · Replies 23 ·
  • · Replies 16 ·
  • · Replies 46 ·
  • · Replies 34 ·
