| Thread Closed |
Luminosity |
Share Thread | Thread Tools |
| Jan2-10, 03:19 AM | #1 |
Luminosity
Question 1 - If two stars A of luminosity 9000 and B of luminosity 90 (both relative to the Sun) appear equally bright from the Earth, how much further away is A from B? Question 2 - Star A is twice as bright as Star B, but B is twice as far away as A. Which star has the greater luminosity, and by what ratio? Question 3 - If two stars, A and B, are the same distance away, but B is 20 times more luminous than A, how much brighter will B appear than A? I could use some assistance as to how I should set these out in accordance with brightness (proportional to) Luminosity / R^2 2. Relevant equations See above 3. The attempt at a solution Question 1 - Worked out to - by moving Star A 10 times further away we have diminished the apparent brightness of Star A by a factor 10 x10 = 100 so that it now matches the brightness of Star B. Question 2 - Worked out to - Luminosity of A Luminosity of B = (½)2 x 2 = ½ This means that Star A really only has half the luminosity of Star B, but appears brighter because it is closer. Ratio 1:2 Question 3 - Worked out to 1/20th . Just need assistance to set these out correctly - and also make sure that they are correct. |
| Jan3-10, 02:11 PM | #2 |
Any thoughts?
| Jan3-10, 07:22 PM | #3 |
Mentor
| Jan3-10, 10:10 PM | #4 |
Luminosity
Zebra, you seem to be really close on the last one. When distance is constant, the apparent brightness is just proportional to the luminosity.
| Jan4-10, 12:15 AM | #5 |
Many thanks for the replies.
Yes, I think I understand what you are saying about question 3. Again, many thanks for the replies. Cheers |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Luminosity
| solar luminosity | Introductory Physics Homework | 1 | ||
| V waveband luminosity | General Astronomy | 0 | ||
| Luminosity | Advanced Physics Homework | 3 | ||
| Plasma luminosity | Astrophysics | 20 | ||
| Luminosity | Introductory Physics Homework | 2 | ||
