Thread Closed
Stainless Steel
Share Thread Thread Tools
Jan2-10, 03:56 PM   #1
Stainless Steel
If there are magnetic and non-magnetic stainless steels,( Martensitic, Ferritic & Austenitic) because of their different physical properties, then what are the trade-offs ’?
For example: Being magnetic is it less durable in resisting rust, scratches ext.) ?
Can you mill or roll one in to shapes easer then the other?
What would be an example of use in a finished product for each?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
Jan2-10, 03:58 PM   #2
Recognitions:
Homework Helper Homework Help
Start here http://en.wikipedia.org/wiki/Stainle...tainless_steel ?
Jan3-10, 09:57 AM   #3
mgb,
If your knowledge base is limited to irony and you find the questions to difficult, then don’t reply with such an ignorant answer.
Jan3-10, 10:44 AM   #4
Admin
Stainless Steel
Quote by Bill 101 View Post
mgb,
mgb_phys pointed to an article that states the differences between austenitic, ferritic and martensitic stainless steels. Composition and microstructure, which is related to composition and thermomechanical treatment, determine the properties such as corrosion resistance, strength, toughness and ferro-magnetism or magnetization.
Furthermore, the article mentions other forms - Precipitation-hardening martensitic stainless steels, which "have corrosion resistance comparable to austenitic varieties, but can be precipitation hardened to even higher strengths than the other martensitic grades," and duplex stainless steels, "which have a mixed microstructure of austenite and ferrite" and "have improved strength over austenitic stainless steels and also improved resistance to localised corrosion, particularly pitting, crevice corrosion and stress corrosion cracking."
One could even clad a one type of steel, e.g., martensitic steel, with an another kind, e.g., austenitic steel (an example of apply a corrosion resistant (protective) layer to a mechanical substrate). However, one must then devise subsequent processes, such as welding with that in mind.
Jan3-10, 01:16 PM   #5
Recognitions:
mgb,
It wasn't an ignorant answer, theres not much point in re-typing an intro to the different types of stainless when wiki does a good job.
Once you know which class of ss you need we can narrow down which exact alloy is best
Jan5-10, 10:01 PM   #6
mgb,
Bill 101:
The folks here are polite.
You are not.
You owe them an apology.
Thank you.
Jan5-10, 10:06 PM   #7
Recognitions:
Quote by spacester View Post
Generally we aren't, but we are normally helpful when it comes to technical answers
Jan6-10, 02:09 AM   #8
Quote by mgb_phys View Post
Agreed. You pointed to a 2,110 word article containg not only the answer to his question, but ancilliary material, as well.
In its earlier years, Wikipedia got a bad rep, but it's content these days is quite remarkable.
Let's get back to the OP's question regarding tradeoffs between "magnetic and non-magnetic stainless steels, (Martensitic, Ferritic & Austenitic)."
Jan24-10, 11:24 AM   #9
trade offs
yup they exihibit superficial properties relevant to others
say,Austenite SS is oftenly used as a biomaterial,commonly in joints(hip joint etc.),valves and may be more.
Jan26-10, 04:49 PM   #10
Since electronic structure is related to magnetism, conductivity, and oxidation (exchange of electrons) they are all related.
I recommend you to read Per Kofstad's "High temperature Corrosion", and see if you still have some questions afterward.
Thread Closed
Thread Tools
Similar Threads for: Stainless Steel
Thread Forum Replies
Iron/Stainless Steel Chemistry 8
Stainless Steel increases B? Classical Physics 5
Which stainless steel? Materials & Chemical Engineering 3
Stainless Steel Chemistry 10
Stainless Steel and Magnetism General Physics 2
