Ice Flowing Upriver: Surprising Sight at Pittsburgh Point
  • Thread starter Thread starter flatmaster
    Ice
The discussion revolves around the observation of ice appearing to flow upriver at Pittsburgh Point, where the Allegheny and Monongahela rivers converge into the Ohio River. Participants explore various explanations for this phenomenon, considering factors such as river currents, wind effects, and the behavior of ice in river confluences.
  • One participant notes that ice appears to be flowing up the Monongahela River, suggesting that the Allegheny may be flowing slightly faster, creating an eddy effect.
  • Another participant questions whether the ice is actually flowing downstream and piling up in an upstream direction, indicating a potential misunderstanding of the flow dynamics.
  • A different participant asserts that there has been no ice coming down the Monongahela, implying that all observed ice must have originated from the Allegheny.
  • One participant speculates that the ice could have frozen in its current position, although they note it was not present earlier in the day.
  • Another participant suggests that a strong north wind may be pushing the ice towards the Monongahela, indicating that the flow in that river is weak, allowing for calm eddy sections.
  • A participant shares insights from water quality monitoring, emphasizing the complexity of flow patterns at river confluences, where differing temperatures or salinities can lead to chaotic flow behavior.
  • One participant observes that there is a visible zone where the waters of the two rivers do not mix, noting differences in color and the presence of ice at the interface.
Participants express differing views on the cause of the ice's movement, with some suggesting wind effects and others focusing on river flow dynamics. The discussion remains unresolved, with multiple competing explanations presented.
Participants acknowledge the complexity of river confluences and the potential for varying flow conditions, but do not resolve the specific mechanisms behind the observed ice movement.
flatmaster
Here is the point at Pittsburgh. The Allegheny is bringing in ice from the top of your picture. the Mon is flowing in from the right. Both rivers empty into the Ohio off to the left. Somehow, Ice flowed up the Mon. THe current is low today with a slight wind blowing left to right on your picture. However, I'm supprised this amount of Ice came up river. My guess is at least 300 ft. Perhaps the Al is flowing slightly faster, creating an eddy on the mon side of the point?
Are you sure ice isn't flowing downstream and piling up in the upstream direction ("backing up" the river)?
It's farily clear down the ohio. I don't think it's backup.
There has been no ice coming down the Mon at all. This all must have come from the Allegheny.
I suppose it's possible the ice froze in this position. However, it wasn't there this morning after the cold night.
It looks like the ice is towards the right (south) side of the Allegheny.
There is probably a strong north wind blowing it that way.
If so, then maybe it's the wind that is blowing it into the Monongahela
and its flow is not all the strong so there is a calm eddy section
without much surface flow.
My guess is eddies & various chaotic flow patterns. When I was studying water quality monitoring we were told never ever bother trying to measure anything near a river confluence. If the water in each tributary is a different temperature or salinity, they will not mix readily and can flow some distance keeping quite separate from each other. Nowhere near as simple as you would imagine.
Furthermore, you can see the zone where the waters don't mix. The "Muddy mon" is a bit browner. Also, you can see ice floating at the interface of the two bodies of water. However, closer to the actual point, the ice doesn't follow this line.
14K
  • · Replies 26 ·
