How Can You Accurately Measure Shear Stress in Structural Members?
  • Thread starter Thread starter Dell
    Area Moment
The discussion revolves around methods for accurately measuring shear stress in structural members, particularly in the context of a civil engineering experiment. Participants explore the use of strain gauges and strain rosettes to determine shear stress and the first moment of area for various beam shapes under transverse loading.
  • Homework-related
  • One participant proposes using strain gauges to measure shear stress in a cantilever beam subjected to transverse loading, suggesting that the shear stress can be calculated using the formula t=VQ/(Ib).
  • Another participant suggests using a strain rosette to measure shear strain and then calculate shear stress by multiplying by 2G, but expresses uncertainty about the placement of the gauges and their effectiveness at the centroid of the beam.
  • A different participant questions the feasibility of gluing two beams together with strain gauges on one to measure shear stress.
  • One participant outlines a method involving placing strain gauges near the fixed end of the cantilever beam and using a strain rosette at 45 degrees to measure strains, which could then be used to find shear stress.
  • Another participant critiques the proposed experiment, arguing that the first moment of area can be calculated directly from geometric properties for a rectangular cross-section, questioning the necessity of the experimental approach.
  • One participant expresses skepticism about the experiment's design, noting that the shear stress distribution is assumed constant, which may not hold true, potentially leading to inaccurate results.
  • Another participant mentions that the e-xx strain will be zero at the neutral axis, reinforcing the complexity of measuring shear strains accurately.
  • One participant compares the proposed method to an unconventional approach of calculating area through tensile loading, suggesting that it may not be the most effective way to determine shear stress.
Participants express a range of opinions on the proposed experimental methods, with some questioning their validity and others attempting to refine the approach. There is no consensus on the effectiveness of the proposed methods or the necessity of the experiment itself.
Participants highlight limitations in the proposed methods, including uncertainties about the placement of strain gauges, the assumptions regarding shear stress distribution, and the need for geometric knowledge to calculate the first moment of area accurately.
Dell
i am a second year civil engineering student, in mechanics of materials we are dealing with twisting and bending moments and our professor has asked us to think up an experiment in which we can "find" the 1st moment of area of different shapes
this is my idea so far but i need some help developing it
i know that when a beam is subjected to transverse loading, the shear stress in the beam is t=VQ/(Ib) therefore
Q=t*I*b/V
now I, b and V are easy to measure, the problem is finding t (the shearing stress)
what i have thought of doing is using strain gages, stick them at a point at which i know the internal shearing stress V, but I am not quite sure how to measure the SHEARING stress using the strain gage, had it been the normal stress i could have used youngs modulus to find the stress through the normal strain, or using a strain rosette(dont think its necessary)
can anyone improve on this or even think of a better way- it doesn't necessarily need to have anything to do with bending and twisting.
o sorry, i can use the strain rosette to find the shear strain and then multiply by 2G to find the shear stress, but how do i set up the rosette since i want to measure at a cetrain point(lets say at the centroid of the beam) how would i place the 3 strain gages? since they are not so small that they will measure my strain ONLY at the center where the shear strain is maximum, - i am working with a regular rectanglular cantilever
another problem i have is how to stick them, since anywhere on the front exposed edge the shear strain will be 0 since there will be no internal shear force?
could i take 2 beams, stick the strain gages on the top of one and then glue them together somehow?
this is my basic idea, can someone tell me if it should work and if there are any problems you can see
i place strain gages on the cantilever beam near where x=0, and the bending moment is F*L
now i use a strain rosette at 45 degrees to measure the strains at x y and 45
through this and using the deformtion equations i can find the xy shear strain
using hookes laws i can now find the xy shear stress and through t=VQ/(Ib) i can find Q
Heck, I don't know, what a strange way to determine (presumably) the first moment of the area above (presumably) the neutral axis, when for a rectangular soild cross section of width b and height h, it's simply Q = area above neutral axis times distance from centroid of area to neutral axis = (bh/2)(h/4) = bh^2/8. I don't get the purpose of the experiment.
that i cannot tell you, i agree, but that is what we were asked to do- fthink of an EXPERIMENT to fint the moment, not use the equation,
will this work?
Sorry, I don't know that much about shear strains and strain gages. I can tell you that the e-xx strain will be 0 at the neutral axis, since ther is no bending stress there; also, in determining the value of Q, knowing the shear stress, you have to use the equation anyway! And also, the shear stress distribution is assumed constant across the width of the beam at a given line parallel to the neutral axis, which is not necessarily true, so your results are going to be off.
e-xx will be 0, as well as e-yy will it not?? but that's just the formality i used because that's the equation, so i will find e-xy=e1/2
I don't know, I'd have to read my 40 year old textbook to find out, since I've never used shear strain equations (only shear stress equations) in my line of work. I still don't like the experiment; it 's sort of like taking a 2 x 2 square section and finding its area by a applying a tensile load, T, to the member, calculating the stress using strain gauges, then using A= P/stress to find the area. I suppose if it was an irregular shape, that might be of some benefit, but in calculating Q of an irregular shape using your method, you still need to calculate I, so that requires a geometric knowledge of the member cross section. Maybe there's another experiment you can do besides using strain gauges (I can't think of one)? Seems weird to me.
13K
10K
