Wideband AC Coupling for DDS Outputs
  • Thread starter Thread starter Jdo300
    Ac Coupling
The discussion revolves around the challenges of designing a wideband AC coupling circuit for Direct Digital Synthesis (DDS) outputs, specifically focusing on achieving offset and amplitude adjustments while maintaining signal integrity across a frequency range of 0.2Hz to 20MHz. Participants explore various circuit configurations and components to address these issues.
  • Jason O describes a problem with offset changes at high frequencies when using a digital potentiometer for amplitude adjustments in his DDS output filter circuit.
  • Some participants suggest using capacitors of various values in parallel to achieve wideband coupling, which may help mitigate issues with reactance at different frequencies.
  • One participant proposes the idea of using a virtual capacitance circuit with op-amps as a potential solution to the coupling problem.
  • Another suggestion involves using an array of high-performance capacitors connected in parallel to reduce inductance while increasing capacitance, although cost may be a concern.
  • A participant outlines a method for independent amplitude and offset control using a potentiometer configuration with an op-amp, although the feasibility of this approach is not confirmed.
  • Jason O later shares that he found a solution by utilizing the differential outputs of the AD9834 DDS IC, which eliminates the offset problem when run through a filter and op-amp.
Participants express various ideas and suggestions, but there is no consensus on a single best approach to the problem. Some solutions are proposed, but the effectiveness of these solutions remains uncertain.
Participants acknowledge limitations related to the ideal behavior of capacitors at high frequencies and the potential impact of inductance. The discussion also highlights the complexity of achieving independent control of amplitude and offset in the circuit design.
Jdo300
Hello All,
I've been playing worth some DDS output filter and amplifier circuits in the simulator and have run into an interesting little problem. I want to make an output that can range from 0.2Hz to 20Mhz and so far I have built a very nice reconstruction filter that can give me a very clean sine wave through that whole range. The problem is that I want to also have offset and amplitude adjustments for the output. I am going with a couple of high speed op-amps with digital pots for the adjustments but things still get complicated because at the high frequency end (10-20Mhz) where the filter begins to attenuate the signal a bit, the offset changes. Also, I have a simple digital pot on the end of the filter with a center tap that I use as the amplitude adjustment. When ever that changes, that effectively changes the DC offset of the signal as well. I was thinking that in the absolute worse case, I could include all these factors in the programming of the microcontroller so that it can compensate for it. But I'm wondering if there is a better way to deal with this problem?
I know it is common to just use a capacitor in series with the output going to the op-amp but i have tried this and it doesn't seem to work so well at very high frequencies or very low frequencies (I tried a 1uF cap with a 47Ohm resistor in shunt to ground). My design does use a bipiolar supply so I'm wondering if I could somehow use this to my advantage. The DDS raw output sine wave is 0 to 600mV though that can vary a bit after it goes through the filter circuit. What do you all think?
Thanks,
Jason O
it's possible to connect capacitors of various values low and high in parallel. That will give you the effect of a wide band coupling. As one capacitor is increasing in reactance, the parallel one can have lower.
I'm no circuit Guru, I only know theory so I'm only good for ideas not experience...
Having said that, while reading my first thought was the series cap which you then mentioned. Clearly for low frequency operation you'll need a high capacitance and the problem at high frequencies is that the cap is not ideal and has some inductance (worse the higher the capacitance).
Some off the cuff suggestions:
Can you find a virtual capacitance circuit using op amps?
What about using an array of high performance caps (suitable for the high freq. domain) connected in parallel (reduces inductance while increasing capacitance) with carefully equal lead length to prevent mixing phases? May be cost prohibitive but it seems you could up the capacitance that way without degrading HiFreq performance.
Hmmm... OK I have a signal in a line relative to ground and I want to output it with independent amplitude and offset adjustments. For amplitude control I would use a pot between signal and ground with tap to the positive input of an op amp.
In addition I'd connect the negative input of the same op-amp to the center tap of a separate pot of high resistance connected across my supply and ground. (High enough resistance so the pot doesn't become an electric heater!) That plus something to keep the gain at unity would (in theory) give you independent control of amplitude and offset.
Did that make any sense? Let me try a diagram:
That should work in principle with the amplifier acting as a unity (or higher if desired) gain difference amplifier. If not maybe it will spark some better ideas.
Yah! that's much better than my array. (Was drawing while you posted).
Hi Everyone, Thank you for your help with this problem. I think I have found a really good solution in my case. The DDS IC that I am using, the AD9834, has a current output DAC with differential outputs. Originally I was going to use it single-ended with my filter circuit and op-amp but after doing some further thinking, I realized that if I simply add a filter for each output and run them both differentially into the op-amp, I can totally eliminate the offset problem all together :smile:. I tested out the final solution and it seems to be working flawlessly.
Thank you all for your help and suggestions though. I'll definitely keep your ideas in mind for my next project.
Thanks!
Jason O
  • · Replies 28 ·
  • · Replies 46 ·
  • · Replies 58 ·
9K
