| Thread Closed |
Calculating the suction force produced by a Venturi |
Share Thread | Thread Tools |
| Jan5-10, 04:14 PM | #1 |
Dear all,
As I understand the venturi effect, if a flow of water passes through a constriction, its velocity increases and its pressure decreases at the restriction. The decrease in pressure allows a suction force to be produced. I am trying to use this principle in order to power a vacuum cup inside a water pipe, but my initial calculations for estimating the suction force are producing seemingly meaningless results. According to WolframAlpha, the formula describing the venturi effect is: [tex]Q=1/4\,\pi\,{{\it D1}}^{2}\sqrt {2}\sqrt {{\frac {{\it P1}-{\it P2}}{ \rho}}}{\frac {1}{\sqrt {{\frac {{{\it D1}}^{4}}{{{\it D2}}^{4}}}-1}}} [/tex] From my understanding, the vacuum pressure generated by the venturi is [tex]P1-P2[/tex]. So, rearranging the above equation to make that the subject gives: [tex]{\it P1}-{\it P2}=8\,{Q}^{2} \left( {\frac {{{\it D1}}^{4}}{{{\it D2}} ^{4}}}-1 \right) \rho{\pi }^{-2}{{\it D1}}^{-4}[/tex] In my situation, I have the following known information:
From the diameter and water speed, I calculate that the flow rate is: [tex]0.02919\,{\frac {{m}^{3}}{s}}[/tex] Other information that is required:
Substituting all of that information into the formula gives us a pressure difference of 1.035716981*10^9 Pa (which looks huge). Assuming that my suction cup has a 15mm radius, in order to work out the suction force I use: [tex]F=PA[/tex] This gives me a suction force of 732105N! This seems extremely high to me, which makes me think that I have misunderstood the principle. Can anyone shed some light on this? Thanks --Amr |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jan13-10, 01:38 PM | #2 |
Any thoughts?
| Thread Closed |
| Tags |
| cup, pressure, suction, vacuum, venturi |
| Thread Tools | |
Similar Threads for: Calculating the suction force produced by a Venturi
| Pressure, force, and Area: Calculating the net Force Applied on A dam by Water | Introductory Physics Homework | 1 | ||
| Calculating pressur produced by explosion | General Physics | 0 | ||
| Force produced by current carrying coil to move sludge(steel rod) | Electrical Engineering | 5 | ||
| Suction related to opening a door quickly | General Physics | 6 | ||
| calculating normal force and net force of 20 kg mass going down inclined plane at... | Introductory Physics Homework | 11 | ||
