Determine the kinetic energy of the emerging neutrons
The discussion revolves around determining the kinetic energy of neutrons produced in a nuclear reaction involving protons and aluminum. The reaction is described as p + 2713Al → 2714Si + n, with a focus on the kinetic energy of the emerging neutrons after the collision.
  • Participants discuss conservation of mass and energy in the context of the reaction. Questions arise regarding the application of relativistic versus non-relativistic kinetic energy concepts. There is also consideration of the binding energy of aluminum and its relation to the kinetic energy of the emitted neutron.
Participants are exploring various interpretations of the problem, with some guidance provided on how to approach the calculations. There is acknowledgment of potential mistakes in previous calculations, and a participant expresses a need for clarity on the correct method before proceeding further.
There is mention of specific masses and energies that need to be looked up, indicating that some information is not provided in the thread. The discussion also hints at the complexity of the reaction and the need to consider relativistic effects.
frankR
A beam of 6.61MeV protons is incident on a tanget of 2713Al. Those that collide produce the reaction
p + 2713Al ---> 2714Si + n
(2714Si has a mass of 26.986721amu.) Neglect any recoil of the product nucleous and determine the kinetic energy of the emerging neutrons.
Okay, what the heck is the idea here?
I tried conserving the mass and the energy. What am I missing?
The correct answer should be 1.00MeV, I get a number much bigger than that.
Without seeing your work, it's hard to tell what you are missing. I remember in another thread you were using nonrelativistic KE in a relativistic particle collision problem. Could that be it?
Whatever I'm doing is way off the mark, so I didn't want to waste time typing it. I need to know the correct way to attack the problem before I start making calculations.
I started looking at it as a collision:
The protons are moving relativistically, I found their speed to be 3.56*10^7 m/s.
What happens during the collision. I know the Al picks up a proton and becomes Si and a nuetral particle is emitted. I looked the binding energy of Al, it comes out to be a really big number, but how much of that energy gives the n particle KE?
Frank,
Don't assume that it's not worth typing out just because your answer is way off. It may be a simple mistake that is easily identified.
Nevertheless...
Before Collision
The total energy of the proton is mpc2+KP, and the total energy of the Al nucleus is mAlc2. You were given Kp, and you'll have to look up mAl.
After Collision
The total energy of the Si nucleus is mSic2 (remember they said you could ignore its motion). The total energy of the neutron is mnc2+Kn. You were given the mass of the Si nucleus and you'll have to look up the mass of the neutron.
Since there is only one unknown here (Kn) you should be able to solve this in short order.
I got it.
kn = (mp - mSi - mn + mAl)*931.5MeV/amu + kp = 1.004MeV
I'm not sure what happened to the nucleon in this collisions/reaction, but I understand the procedure.
  • · Replies 54 ·
12K
  • · Replies 20 ·
  • · Replies 21 ·
