Do I need to calculate in car and trailer tension separately?
  • Thread starter Thread starter lemon
The problem involves a car towing a trailer, with specific masses and an acceleration provided. Participants are exploring the calculation of the driving force and the tension in the coupling between the car and the trailer, while questioning the interpretation of external forces.
  • Mixed
  • Participants discuss the definition of external forces and whether the driving force includes friction. There are attempts to calculate the tension in the coupling, with some expressing uncertainty about the need to calculate tensions separately for the car and trailer.
Some participants have provided calculations for the driving force and tension, while others have questioned the assumptions made in those calculations. There is a recognition of the need to consider forces on individual components, but no consensus has been reached on the correct approach to calculating tension.
Participants are navigating the constraints of the problem, including the definitions of forces involved and the implications of Newton's laws. There is a mention of potential errors in mass assignments in calculations, which may affect the results.
lemon
1. A car of mass 1000kg is towing a trailer of mass 650kg and the two have an acceleration of 2,3m/s^2. Assuming that the only external force is the driving force between the wheels and the road, calculate:
1: the value of this force
2: the tension in the coupling between the car and the trailer.
I'm a little unsure about this question. When it says 'external force', the driving force between the wheels and the road, it does just mean the driving force, right? And not the frictional force?
Also, my calculations for tension have come out at 0N. But I think there must still be a Tension/resultant force between the two vehicles as they are not moving at a constant velocity. Do I need to calculate in car and trailer tension separately?
2. F=ma
F-T=ma
3.
(a) F=(1000kg+650kg)2.3m/s^2
=2500N (2sf)
(b) F-T=ma
T=F-ma
T=2500-2500=0
Welcome to PF!
Hi lemon! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
They're the same …
by good ol' Newton's third law, action is equal and opposite to reaction, so the (drive) force of the car on the road equals the (friction) force of the road on the car. :wink:
(b) F-T=ma
T=F-ma
T=2500-2500=0
Yes, you can only find T if it's an external force, so that means that you must consider only the forces on the car (or only the forces on the trailer).
(So your m in that last equation is wrong.)
Welcome to PF!
They're the same …
(b) F-T=ma
T=F-ma
T=2500-2500=0
Welcome to PF!
They're the same …
(b) F-T=ma
T=F-ma
T=2500-2500=0
Hi:
So, to answer part b correctly:
Car: 2500N-T=1000kg x 2.3ms
T=2500N-2300N=200N
Trailer: 2500N-T=650kg x 2.3m
T=2500N-1495N=1005N
Total T=Tcar+Ttratiler=200N+1005N=1205N
test
ms-2
lemon said:
Hi:
T=2500N-2300N=200N
T=2500N-1495N=1005N
lemon said:
test
lemon said:
ms-2
Hi lemon! :smile:
I see you had the same problem as I did, with the server! :biggrin:
Your car equation is completely correct …
and you should have stopped there! :wink: :rolleyes:
Your trailer equation is wrong, because there's only one force on the trailer, and that's T.
F is a force on the car, not on the trailer … all the trailer gets is what comes through the coupling.
So you could have said T = mtrailera, which would give you the same result as F - T = mcara … either will do, but the first one is shorter. :wink:
You rock! Roll! Rave!
Whatever.
Thanx
  • · Replies 25 ·
