Thread Closed
If the change in temperature of the water is bigger, does it mean that more heat is l
Share Thread Thread Tools
Jan6-10, 01:03 PM   #1
If the specific heat capacity of water from an experiment is smaller than its actual value, does it mean more heat is lost to the surroundings? If the heat is emitted by a wire into a cup of water and the change in temperature is measured, does it mean that the change in temperature of the water would bigger if more heat is lost to the surroundings?
2. Relevant equations
∆T/time = (1/mc)*IV
3. The attempt at a solution
so if c is smaller (more heat energy lost to surroundings) then the RHS will be bigger, meaning the LHS must be bigger to balance the equation. Therefore ∆T must increase.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jan6-10, 02:19 PM   #2
anyone???
Jan7-10, 10:11 AM   #3
no one :(
Jan7-10, 10:45 AM   #4
Recognitions:
Homework Helper Homework Help
Quote by acronym View Post
Lower specific heat capacity means that less energy is lost to reduce temperature by the same amount.
I think you have a couple of questions/different principles confused here.
The rate of heat loss into the surroundings depends on the temperature difference.
How quickly this changes the temperature depends on the heat capacity.
It will also depend on the amount of power being supplie dby the wire.
What exactly is the question?
ps. replying to your own question if nobody answers is a bad idea - it marks the question as 'answered' so people ignore it. Remember PF readers are all over the world so it may take 12hours if you post it while the US or Europe is asleep.
Jan7-10, 12:16 PM   #5
In an ideal world, rate of thermal energy absorbed by the water = rate of electrical energy developed by the wire, as the wire gives off heat. But in the real world, some of the electrical energy converted into heat will not all go to heat up the water, but to the surrounding air instead, especially if the cup of water is not insulated. This will make the calculations for the SHC lower than the actual value.
It seems logical that since less heat is gone to heat up the water, the change in water temperature should be lesss--so c is smaller because ∆T is smaller.
However, in the formula ∆T/time = (1/mc)*IV it seems that if c smaller, ∆T will actually be larger (to balance the equation). So where is my reasoning going wrong?
Sorry, I seldom come to this site so I don't know how it works =/ Hope you'll answer my question...
Jan7-10, 12:27 PM   #6
Recognitions:
Ok - you are asking how will heat loss effect you measurement of SHC in the experiment?
If you supply a certain amount of electrical energy, and you assume that Q = mcT (with no heat lost).
Then if heat is lost to the surroundings you will measure that more energy is required to heat the water than is really true so you will determine that C is higher (it is harder to heat water) than is correct
Jan7-10, 01:28 PM   #7
So...c should be bigger?
But c is supposed to be smaller if heat is lost to the atmosphere...
My teacher says so and this too:
http://wiki.answers.com/Q/Why_specif...acity_of_water
Could you please explain in detail why it is so? And how this is shown in the equations? Thanks.
Jan7-10, 01:32 PM   #8
Recognitions:
You would measure C as bigger than it is, so the value of C would be smaller than you measure.
The only equation is that Q is proportional to C
Jan7-10, 02:07 PM   #9
Oh...so it's hypothetical...
we imagine that Q will have to increase because more energy will be needed for the water to reach the same temperature without heat loss...so c must also be considered bigger to balance the equation.
Therefore in reality, c should be smaller since Q absorbed is less (due to heat loss)?
Jan16-10, 10:12 AM   #10
well, thanks a bunch!^^
Thread Closed
Thread Tools
Similar Threads for: If the change in temperature of the water is bigger, does it mean that more heat is l
Thread Forum Replies
Heat and Internal Energy and Heat and Temperature Change: Specific Heat Capacity Advanced Physics Homework 4
What will be the change in temperature of the water? Biology, Chemistry & Other Homework 2
Temperature and Internal Energy/Time to heat water Advanced Physics Homework 1
Heat up water with low temperature steam Engineering, Comp Sci, & Technology Homework 2
Temperature change of water at triple point in a constant-volume gas thermometer Advanced Physics Homework 0
