Conservation of angular momentum of a falling particle
The discussion centers on the conservation of angular momentum in the context of a stone dropped from a helicopter 500 meters above the ground at the equator. The participant, Rupe, calculated the horizontal distance the stone lands from the point directly below the helicopter, arriving at 12 cm instead of the expected 24 cm. The calculations involved angular momentum equations and integration over time, indicating a potential error in the setup of the equations rather than the integration process itself.
  • Understanding of angular momentum and its conservation principles
  • Familiarity with basic kinematics and projectile motion
  • Knowledge of calculus, specifically integration techniques
  • Concept of Earth's angular velocity and its effects on falling objects
  • Review the principles of conservation of angular momentum in physics
  • Study projectile motion equations and their applications
  • Learn advanced integration techniques relevant to physics problems
  • Explore the effects of Earth's rotation on falling objects in detail
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in the practical applications of angular momentum in real-world scenarios.
Rudipoo
A stone is dropped from a stationary helicopter 500m above the ground, at the equator. How far from the point vertically below the helicopter does it land?
Conversation of AM
Let the height above the ground it is dropped be h, the radius of the Earth R, the mass of the stone m (which will cancel) and the angular velocity of the Earth w. Then the angular momentum as it's dropped is mw(R+h)^2.
When the particle is at a height y above the Earth's surface, the stone has angular momentum m(R+y)(v_x+v_0) where v_0=(R+h)w is the velocity (in x direction) when it dropped, due to the helicopter being stationary, w.r.t. the Earth.
Now, y=h-0.5g*t^2, and Conservation of AM implies
mw(R+h)^2=m(R+h-0.5g*t^2)(v_x+(R+h)w).
I rearranged for v_x and integrated between t=0 and t'=Sqrt(2h/g), the time for the stone to hit the ground.
I go the answer x=12cm, but it should be x=24cm. Am i performing the integration incorrectly or have I set up the equations wrong?
Thanks, Rupe
I get the same answer of 12cm by doing the integral, so it seems like the problem is in your setup. Though I don't immediately see what you might have done incorrectly.
Thanks for your help diazona. That improves my confidence in the integration. I wonder if anyone can see my mistake in setting up the equation?
Thanks.
  • · Replies 17 ·
18K
  • · Replies 20 ·
