Proving Positive Integral using Sums
The discussion revolves around proving that the integral from 0 to x of (sin t)/(t + 1) dt is greater than zero. Participants are exploring the properties of this integral and its behavior over specified intervals.
  • Participants discuss the use of lower and upper sums to approximate the integral and question the validity of their calculations. Some suggest examining the derivative of the integral to determine if it is increasing. Others raise concerns about the oscillatory nature of the sine function and its impact on the integral's positivity.
The conversation is ongoing, with various interpretations of the integral's behavior being explored. Some participants have offered informal reasoning regarding the positivity of the integral over certain intervals, while others express the need for a more formal proof due to academic expectations.
Participants note that they have not yet learned how to differentiate an integral, which may limit their approaches. There is also mention of differing expectations regarding the formality of proofs in their coursework.
SpringPhysics
Prove that the integral from 0 to x of (sin t)/(t + 1) dt > 0.
(Sorry I don't know how to use the integral latex.)
We have only learned about lower and upper sums, and how the integral is equal to the supremum of lower sums and the infimum of upper sums when sup = inf
I took a partition from 0 to x with equal intervals, so that each interval has length x/n for n intervals. I found the lower sum and upper sum, with a difference of x/n * (sin x)/(x + 1). I have no idea what to do afterwards. Am I to eliminate the possibility of the integral being 0 and negative?
EDIT: I "found" the lower and upper sums incorrectly - in fact, they are not possible to determine.
Your integral is a function of x, f(x), with f(0) = 0. If you can show that f'(x) > 0 then you can conclude that f is increasing, hence its integral will be positive.
Here's the LaTeX for your integral.
[tex]\int_0^x \frac{sin t}{t + 1}dt[/tex]
Wouldn't that exclude the decreasing portion of the function for x > 0, since sine is periodic? Moreover, it wouldn't show that the difference between the area of the first and second arcs is positive.
The function I'm talking about is not (sin t)/(t + 1), which does oscillate as you describe. The one I'm talking about is the integral. The area under the first arch is positive, and is more positive than the negative "area" above the second arch, so overall for the two arches, the integral is positive. It's sort of like adding 5 - 2.5 + 1.25 - .625 + - ... and so on. Each partial sum is positive, despite half the terms being negative.
I believe the approach you need to take is as I described in my previous post.
Ohhhh. I will try that then, thanks.
I got
lim as h -> 0 of [tex]\frac{f(x + h) - f(x)}{h}[/tex] =
lim as h -> 0 of [tex]\frac{\int_x^(x+h) \frac{sin t}{t + 1}dt}{h}[/tex]
I'm stuck here, as I tried to equate the limit to a constant c greater than zero, then using the delta-epsilon definition of the derivative. Then I get a delta dependent on the value of x, which means that the function is not uniformly continuous (but it must be because it is continuous in a closed interval).
The integral of sin(t)/(1+t) is positive from 0 to pi. No doubt about that, right? Now the integral from pi to 2pi is negative. But it will be less in absolute value than the positive part of the integral from 0 to pi. Since 1/(1+t) is less on the interval [pi,2pi] than it is on [0,pi]. Similarly the integral on [2pi,3pi] is positive, integral on [3pi,4pi] is negative but less in absolute value than the former. Etc etc. That's what Mark44 was talking about. It's not really a derivative problem.
But that's not really a proof right? That's just an intuitive solution.
Also, we have not learned how to differentiate an integral.
It's not just an 'intuitive solution'. It's an informal description of a legitimate proof. How formal you want to make it depends on the requirements of your class. I think if you understand that and describe it clearly, that's all you need.
I was thinking of showing the same description for the proof. Usually, my professor is lenient but the people marking are very harsh and always demand a formal proof.
I think you are being overly concerned. You can't prove the derivative of your integral is positive, because it's not. It does decrease sometimes but can never decrease to zero because of the area argument. Some things aren't worth being overly formal about.
All right then, thanks to the both of you for your help!
